> Six - Oil Lines, And Draining Oil
jfort
post Jan 27 2019, 05:17 PM
I have after market oil lines with AN fittings. The line from the tank to the cooler has a leak. Apparently at the cooler end. As I think about replacing the line, I’ve been thinking about putting in a fitting at the tank end with a valve or a threaded hole for a drain plug. Something to make draining the oil easier than disconnecting the hose. Anyone here ever done such a thing?
Replies(1 - 19)
post Jan 27 2019, 05:23 PM
914-6 GT in waiting
Sorry, pic is turned sideways. An next time I drain the oil, I plan to safety wire the cap. Even though it points down, this pic is without the heat exchangers installed. They sit at least a couple inches lower than the T.
mb911
post Jan 27 2019, 05:42 PM
The lines I sell have a union in the middle of the main line. This allows for a way to drain there.
gms
post Jan 27 2019, 07:42 PM
As confident as I am that I would never leave a valve between my oil tank and engine closed I just cannot do it...too high a price to pay for a forgetful moment.
The T in the lines is a pretty good solution IMO
Mark Henry
post Jan 27 2019, 08:14 PM
that's what I do!
A Tee with an EZ drain would be the best.
But...even then you will never get complete drainage (IMG:style_emoticons/default/wink.gif)
gereed75
post Jan 27 2019, 10:00 PM
A simple solution is to drill a hole in the union between the tank hose and the cooler hose and tap the hole for a short bolt. I used an M6. I drilled the bolt head for safety wire.
Snip the wire, remove bolt, drain tank and lines, replace bolt. Rewire. I use a copper washer to seal the bolt.
Small. Simple. Safe. Works. If you forget to replace the bolt you will know right away.
post Jan 27 2019, 10:26 PM
914-6 GT in waiting
QUOTE(Mark Henry @ Jan 27 2019, 09:14 PM) *
Same with 911’s. Especially if you have a front oil cooler.
GeorgeRud
post Jan 28 2019, 09:43 AM
The factory solution with a connection at the oil line hanger works well, but a simple T fitting there would make for a cleaner draining experience. Amazing how much oil drains very quickly once those lines are disconnected.
mb911
post Jan 28 2019, 09:56 AM
I have also made tanks with 911 drains before .. This works pretty well.
Mark Henry
post Jan 28 2019, 01:25 PM
that's what I do!
QUOTE(GeorgeRud @ Jan 28 2019, 10:43 AM) *
That's what I did, SS 3/4" Tee cut off the ends and welded on factory ends. Hangs on the hook. Might have been a 7/8" tee, the ID was the same as factory fittings.
The T has a 3/8" NPT plug in it, if I was to do it over I'd get a tee that takes a 1/2"NPT plug. Was going to use an EZ drain, but the NPT plug is really easy.
MoveQik
post Jan 28 2019, 01:32 PM
What size wheels can I fit?
I have the same set up as Mepstein and it has worked perfectly for 12 years :-)
post Jan 28 2019, 01:54 PM
914-6 GT in waiting
QUOTE(MoveQik @ Jan 28 2019, 02:32 PM) *
I copied the setup from someone. Ive read your build thread many times so it might have been you. (IMG:style_emoticons/default/beerchug.gif)
targa72e
post Jan 28 2019, 03:16 PM
I have -16 lines and used this between the line to the tank and the cooler.
https://www.ebay.com/itm/16AN-AN-16-MALE-FE...=item2a771f1ad0
john
infraredcalvin
post Jan 29 2019, 12:01 AM
Distracted Member
I saw somewhere somebody (maybe elephant racing?) installed a Schrader (air) valve in 911 oil line to the front cooler so they could pressureize and force old oil out.
infraredcalvin
post Jan 29 2019, 12:03 AM
Distracted Member
Ahh yes, here it is...
https://www.elephantracing.com/porsche/911/...es/#prettyPhoto
sixnotfour
post Jan 29 2019, 12:09 AM
I just uncouple the oil lines...not in a hurry
jd74914
post Jan 29 2019, 07:49 AM
Its alive
QUOTE(infraredcalvin @ Jan 29 2019, 01:01 AM) *
That's neat-I like that idea. I didn't realize until now (google search) that high temperature/pressure Schrader valve bodies/seals existed.
jfort
post Feb 1 2019, 08:46 AM
Hose taken to hose maker. It was leaking at the cooler end, the straight end. Making a new hose with aluminum fittings. This steel stuff is too heavy. Will drill and safety wire the cap. That's the plan anyway.
Cairo94507
post Feb 1 2019, 09:13 AM
Michael
I would like to add a drain fitting in my oil line as well. I would rather not disturb the main connections for routine maintenance when you want to drain the tank/oil. This option seems like a great way to go. (IMG:style_emoticons/default/beerchug.gif)
Mark Henry
post Feb 1 2019, 12:41 PM
that's what I do!
My solution. (IMG:style_emoticons/default/smile.gif)
- Lo-Fi Version Time is now: 2nd April 2026 - 02:54 PM
