Mallory electric fuel pumps, anyone? if so,, how did you plumb it and the filters?? |
Mueller |
Jun 21 2005, 08:25 AM
Mallory makes an electric pump for both carbs and fuel injection all models have a 3/8 NPT inlet/outlet.
For fuel injection, they recommend a filter before the pump and a filter before the injectors. What I am not too sure about is how to plumb it all, from what I can find, it looks like it'll have to be all -6 AN fittings. Now to figure out what brand fittings and hose (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) (IMG:http://www.jegs.com/photos/6505250.jpg) |
E-Man |
Jun 21 2005, 08:56 AM
Member Group: Members Posts: 158 Joined: 4-March 03 From: S. Windsor, CT Member No.: 390 |
I have dual 44IDFs currently and a Mallory pump like that one.
The set-up on the car is: Gas tank | line | filter | line | 90 deg. fitting | pump | 90 deg. fitting | line thru center tunnel | 90 deg. fitting | regulator(1-in, 2-out) | filters | carbs The pump is mounted in the front trunk in the later FI pump location. AN-8 fittings and SS hose were used. While I was at it, I also ran a return line for future FI and capped it. Pictures to follow. -Mike |
Mueller |
Jun 21 2005, 10:37 AM
thanks Mike.....
how did you do the hose from the tank to the filter? AN fittings or slip/clamp fit? I cannot seem to find a 3/8 npt fitting that has a barbed fitting for the hose |
SteveSr |
Jun 21 2005, 10:51 AM
Member Group: Members Posts: 203 Joined: 7-October 03 From: Knox,In. Member No.: 1,223 |
Mike, you might try here,http://www.pegasusautoracing.com
they have tons of fuel line fittings....................... Steve |
E-Man |
Jun 21 2005, 11:03 AM
Hose clamp works fine there, even with FI since the pressure is provided later on via the pump.
I think I used Jegs or Summit for the SS hose and AN fittings. -Mike |
machina |
Jun 21 2005, 11:08 AM
Advanced Member Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
I used the 3/8 =>-6 fittings to save space.
the mallory pumps are really nice. I have carbs and the low pressure pump only draws 2.5 amps compared to 5 amps for the typical holley. also, the mallory has a fine billet pump housing where the holley was cheap pot metal that cracked and leaked. Attached image(s) |
maf914 |
Jun 21 2005, 11:31 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
David, Does the mallory pump make much noise? Some electric pumps can be irritatingly loud for street use, (i.e. Facet). (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) |
MikeP |
Jun 21 2005, 11:40 AM
Member Group: Members Posts: 321 Joined: 13-June 05 From: San Jose, CA Member No.: 4,268 |
If you can hear ANY fuel pump you aren't running a big enough engine!
maf914 |
Jun 21 2005, 02:16 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) That's good! (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
redshift |
Jun 21 2005, 02:22 PM
Bless the Hell out of you! Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 |
Which reminds me of the first time Ms. Charlene went riding with me in my teener... unreal loud assed pump...
"That buzzer..." "Yeah?" "Does that go off when it warms up?" "Hmmm.. hope not.." (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) M |
machina |
Jun 21 2005, 02:25 PM
its quieter than the holley and just barely loud enough to know its running. I like that because i have the pump and ignition switched independently so when I energize the pump, i know its running before I startup. doing all these -AN lines, I became obsessed with finding the cleanest and shortest way to connect things. Like always using a hose end that fit directly instead of say getting an adapter to go from -3/8 => -6 and then using a -6 hose end. It just makes the install better and I think a bit safer not to have several inches of fittings hanging off the end of a hose. sometimes I would have to get a russell fitting if earls or AQ didn't make it or have it in stock or in aluminum vs steel etc. i would always order form summit. they would have most every fitting and if I ordered online by late afternoon, the stuff shipped out that day. They never let me down. |
Thorshammer |
Jun 21 2005, 02:34 PM
Senior Member Group: Members Posts: 749 Joined: 11-November 03 Member No.: 1,335 |
Got mine from summit as well. 159.95??
excellent pump, had to take mine apart to see what makes it tick, Nice stuff. It must be mounted so that the electric motor is above the pump housing, if you mount it upside down, and it leaks, it can start a fire. it does draw much less current than the holley. Erik Madsen |
Mueller |
Jun 21 2005, 03:32 PM
thanks Steve....I couldn't find any 3/8npt to barb fittings larger than 1/4" (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) |
Aaron Cox |
Jun 21 2005, 04:24 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
i think jwest or engman has the tank fitting to AN6 adapters. go braided line all the way mikey? BTW - i hear these pumps are noisy mofo's |
0396 |
Jun 21 2005, 05:47 PM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
Mike,
I'm currently running a Holley Blue pump up front. From there -6 AN Aeroquip to the back, then a fuel regulator to a small micron filter to my webers. (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) |
Jake Raby |
Jun 21 2005, 06:54 PM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
The Mallory is the EFI pump that I have chosen for my engines and FI kits. You can't go wrong with any Mallory component..
BTW guys, wait until you see the R&D that I did today with carbs Vs. EFI on a 2739cc engine... I dynoed it all day today and data logged all the information- its impossible to lie with data logged files.. |
Mueller |
Jun 21 2005, 07:01 PM
jwest has them...$25 each (2 needed if doing return line which I need) i wish I hadn't thrown away that extra gas tank I had, otherwise I would have a better idea on the size of the fittings under the tank and my options.... |
McMark |
Jun 21 2005, 07:04 PM
I have extra gas tanks. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
Mueller |
Jun 22 2005, 04:24 PM
found a new pump made by MSD, looks very close to the stock front trunk mounted /4 tanks:
(IMG:http://www.msdignition.com/fuel/2225_big.jpg) $92.00 from Summit Racing, I think I'll be going with this one instead, it's almost $50 less than the Mallory and it'll fit better in the stock location. |
TimT |
Jun 22 2005, 04:29 PM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
Mike check out
Walbro fuel pumps I have a Walbro pump thats good for 500hp in my car, and its the size of a Red Bull can.. they also have many different fuel line adapters you can get these pumps at many other sites also |
Lo-Fi Version | Time is now: 8th June 2024 - 02:12 AM |
