Subaru cooling help, Hose routing |
Mowog4 |
Mar 10 2019, 10:58 AM
Member Group: Members Posts: 291 Joined: 2-November 15 From: Mesa AZ Member No.: 19,325 Region Association: None |
I recall reading a post about someone running coolant lines through the heating ducts through the cabin. I have been searching for it, but can’t Find it. Anyone remember the post?
Thanks |
mepstein |
Mar 10 2019, 11:05 AM
914-6 GT in waiting Group: Members Posts: 19,313 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I think Amerson did it to his Suby car.
76-914 |
Mar 10 2019, 11:14 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,508 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I forget what page.................. http://www.914world.com/bbs2/index.php?showtopic=201776
Mowog4 |
Mar 10 2019, 11:37 AM
You guys are great, thanks!
JRust |
Mar 10 2019, 01:32 PM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
It is trickier getting all the air out of the system when it's run that way. The Extra Peaks & Valley's made it tough. I always had issues with cooling my v8 when it was run that way. Wasn't a problem again when I finally ran them straight under the car. A suby is a bit more forgiving cooling wise though
76-914 |
Mar 10 2019, 06:23 PM
As I found out, SBC old school V-8's are a different breed. The na Subaru is a much more efficient engine and doesn't produce or hold much heat. I never had a cooling problem when I had the small coolant lines run through the longs. Nor did get any heat in the cabin from having run those lines through the longs. The only reason that I changed to the under carriage route and larger hose is ignorance on my part. I was chasing my own tail at the time. When you run the lines down, up and back down they can trap some air but look and you'll see hose clamps that can be loosened to bleed the air at the high points. Quick and easy to bleed. (IMG:style_emoticons/default/beerchug.gif)
Chris914n6 |
Mar 10 2019, 08:16 PM
Jackstands are my life. Group: Members Posts: 3,336 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Just run them under the car like all the people that have never had problems.... (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 8th June 2024 - 09:00 AM |
