WTB: CHT Sensor and Sensor Extension, For 73 2.0 |
SRS914 |
Sep 6 2019, 01:23 PM
Newbie Group: Members Posts: 22 Joined: 10-August 18 From: Laguna Beach Member No.: 22,379 Region Association: Southern California |
Need tested or NOS CHT specifically for the 73 2.0. Part numbers 022 906 041 A or 0 280 130 017. Also want to give a CHT extension a try if anyone has one for sale.
Mikey914 |
Sep 7 2019, 02:15 AM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Attached thumbnail(s) |
KevinW |
Sep 7 2019, 06:14 AM
Newbie Group: Members Posts: 42 Joined: 25-May 15 From: Winona, Minnesota Member No.: 18,761 Region Association: Upper MidWest |
I think Brad at 914LTD has the extensions. That’s where I bought mine.
SRS914 |
Sep 7 2019, 12:39 PM
Unfortunately the 73 2.0 requires the specified part number to run correctly. Thank you for the suggestion. |
GaroldShaffer |
Sep 7 2019, 10:47 PM
You bought another 914? Group: Benefactors Posts: 7,624 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
Call Brad Mayeur's shop 914LTD On Monday 309-694-1797 he sells the standoff and just might have the head temp sensor also.
Jett |
Sep 8 2019, 09:04 AM
Senior Member Group: Members Posts: 1,641 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
What is the downside of having the wrong type of CHT? I ask because our 73 2.0 runs exceptionally well but the temp gauge in the console only moves slightly when warmed up. Although this might be fine, the car is having warm start issues. If I cycle the fuel pump a few times the car will most likely start.
Mikey914 |
Sep 8 2019, 01:43 PM
Unfortunately the 73 2.0 requires the specified part number to run correctly. Thank you for the suggestion. Actually it needs the additional resistor I'm currently running on mine (73). Mark |
Mikey914 |
Sep 8 2019, 01:45 PM
What is the downside of having the wrong type of CHT? I ask because our 73 2.0 runs exceptionally well but the temp gauge in the console only moves slightly when warmed up. Although this might be fine, the car is having warm start issues. If I cycle the fuel pump a few times the car will most likely start. It's a matter of resistance the 73 required the additional so the resistor is added inline. |
Jett |
Sep 8 2019, 03:12 PM
What is the downside of having the wrong type of CHT? I ask because our 73 2.0 runs exceptionally well but the temp gauge in the console only moves slightly when warmed up. Although this might be fine, the car is having warm start issues. If I cycle the fuel pump a few times the car will most likely start. It's a matter of resistance the 73 required the additional so the resistor is added inline. What does the resistor look like? I recall these on a group buy some time back... |
Mikey914 |
Sep 8 2019, 04:11 PM
Never did a resistor GB, just the CHT sensor.
if I recall correctly it a 350 (or 300)ohm resistor that has the spade male and female in line so it can easily be added in line. |
SRS914 |
Sep 9 2019, 12:31 PM
SRS914 |
Sep 9 2019, 01:41 PM
What is the downside of having the wrong type of CHT? I ask because our 73 2.0 runs exceptionally well but the temp gauge in the console only moves slightly when warmed up. Although this might be fine, the car is having warm start issues. If I cycle the fuel pump a few times the car will most likely start. It's a matter of resistance the 73 required the additional so the resistor is added inline. I'm currently running the correct CHT and the stock resistor. Runs good until I shut it off. Starts when hot but then sputters and just doesn't run smooth for about 10 minutes or until the heat has transferred evenly again. I wanted to try another correct CHT and a standoff to see if that might help the issue. |
Jett |
Sep 9 2019, 10:07 PM
What is the downside of having the wrong type of CHT? I ask because our 73 2.0 runs exceptionally well but the temp gauge in the console only moves slightly when warmed up. Although this might be fine, the car is having warm start issues. If I cycle the fuel pump a few times the car will most likely start. It's a matter of resistance the 73 required the additional so the resistor is added inline. Thanks Mark, On the GB thread (http://www.914world.com/bbs2/index.php?showtopic=294539&st=60) you stated never to use resistor with your unit, has this changed? What is the specific setup for your 73. 2.0? "The 1973 2.0L's came with the: 0280130017 head temperature sensor, 039971762A ballast resistor, 0280100037 manifold pressure sensor, and the 022906021E version of the ECU. |
Mikey914 |
Sep 10 2019, 03:33 AM
Does it smell rich when it's not running when warm? It almost sounds like the cht may be going out. When hot it should have almost 0 resistance. allowing a lean condition. When cold it should enriches (has more resistance). If this is the culprit the standoff would not help.
I'm wondering if the issue may be something else. This post is worthy of the garage you may find more help there. |
Jett |
Sep 10 2019, 08:42 AM
Does it smell rich when it's not running when warm? It almost sounds like the cht may be going out. When hot it should have almost 0 resistance. allowing a lean condition. When cold it should enriches (has more resistance). If this is the culprit the standoff would not help. I'm wondering if the issue may be something else. This post is worthy of the garage you may find more help there. Thanks Mark, the car runs at 95% for three minutes and then perfectly — fuel mix smells good. The problem is that if I stop after 20 minutes, the car will not start unless I cycle the fuel pump several times and then it starts. The fuel pump is NOS, but tried a refurb from AA and no difference. I’ll move this to the garage. cheers |
SRS914 |
Sep 11 2019, 10:51 PM
Does it smell rich when it's not running when warm? It almost sounds like the cht may be going out. When hot it should have almost 0 resistance. allowing a lean condition. When cold it should enriches (has more resistance). If this is the culprit the standoff would not help. I'm wondering if the issue may be something else. This post is worthy of the garage you may find more help there. It does smell rich from the moment I start it but the plugs look great. |
Superhawk996 |
Sep 12 2019, 04:16 AM
914 Guru Group: Members Posts: 5,892 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Never did a resistor GB, just the CHT sensor. if I recall correctly it a 350 (or 300)ohm resistor that has the spade male and female in line so it can easily be added in line. I happen to have one sitting next to the computer. Measures 275 ohms. I think they are actually 250 Ohm specification IIRC but resistors often have a 10-20% tolerance. So I'm betting mine is 250 ohm +10%. |
GregAmy |
Sep 12 2019, 08:29 AM
Advanced Member Group: Members Posts: 2,311 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
What is the downside of having the wrong type of CHT? So, while this should probably be in The Garage, a bump for this. Really, why does it matter what the resistance is, if we're effectively going to wreck its designed function with a spacer to slow down the drop in resistance? There's two CHT sensors: per Paul's specs, 0 280 130 003 for the 1.7 and 0 280 130 012 for the 2.0. Normal Value(s): 0 280 130 003 and 0 280 130 012: about 2.5 K ohms at 68 deg. F, less than 100 ohms with hot engine. 0 280 130 017: about 1.3 K ohms at 68 deg. F, less than 100 ohms with hot engine. The function of the CHT is to "tell" the ECU that the engine is cold, please richen the fuel. This happens at higher resistance. Both are the same value when hot ("less than 100 ohms") so the wrong CHT doesn't matter after warmup. By adding a spacer, we're slowing the conduction of heat to the CHT< keeping the resistance higher, longer. Therefore...if we install the 2.5K ohm sensor on an engine that needs the 1.3K ohm sensor, then it keeps the car richer longer, but ends up in the same place once the engine is hot (and reducing the need for the spacer). If we install the 1.3K ohm sensor on an engine that needs the 2.5K ohm sensor, then it leans the engine sooner, but ends up in the same place once the engine is hot. But that can be compensated by installing the spacer. So where's my disconnect here? |
Superhawk996 |
Sep 12 2019, 10:36 AM
Bottom line is idle quality and drive ability during the transient conditions.
ECU is an analog circuit that was designed around a specific sensor and inherent non-linear resistance curve. There is no closed loop control to adapt like a modern FI system has. I’m with you on the spacer thing though. Adds another uncontrolled variable into the mix but historically some had success to their own liking (whatever that might be) with the spacer. |
Lo-Fi Version | Time is now: 7th June 2024 - 10:23 PM |
