mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,598 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
lierofox |
Member ![]() ![]() Group: Members Posts: 256 Joined: 23-June 15 From: Paso Robles, CA Member No.: 18,880 Region Association: Southern California ![]() ![]() |
mb911 |
What relay would this be? Seat belt interupter? Seat belt interlock would be under the passenger seat. The wire colors for that look like a High/Low beam dimmer relay. Ok that helps as well.. As I figure out the 911 switch conversion.. |
GregAmy |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,505 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States ![]() ![]() |
I name it "Aloysius".
bbrock |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains ![]() ![]() |
I name it "Aloysius". Sounds like as good a name as any. Aloysius' job is the headlight relay as already indicated. If you have to replace it, the new one will have an extra terminal that needs to be jumpered to the power terminal to make it work. There are threads on it somewhere. |
mb911 |
I like this game..
raynekat |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,169 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest ![]() ![]() |
I'll call that relay "Bob."
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,422 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
What relay would this be? Seat belt interupter? Seat belt interlock would be under the passenger seat. The wire colors for that look like a High/Low beam dimmer relay. Ok that helps as well.. As I figure out the 911 switch conversion.. If you are using a 911 turn signal switch, you don't need the relay. The /4 turn signal switch is a momentary contact switch to trigger the relay. The 911 switch is a push/pull switch that wires directly into the headlight circuit. With the 911 switch I would suggest that you add a relay kit at the headlights. That takes the amp load off the 911 switch and makes it last much longer. This kit makes it easy: http://www.allzim.com/store/zim-s-12v-brig...ategory_id=1127 All you have to do is to extend the 12V wires. I have them fused, and I ran them all the way to the battery. If you need help with the wiring, let me know. I can make diagrams for you on how to change stuff like this. |
mb911 |
What relay would this be? Seat belt interupter? Seat belt interlock would be under the passenger seat. The wire colors for that look like a High/Low beam dimmer relay. Ok that helps as well.. As I figure out the 911 switch conversion.. If you are using a 911 turn signal switch, you don't need the relay. The /4 turn signal switch is a momentary contact switch to trigger the relay. The 911 switch is a push/pull switch that wires directly into the headlight circuit. With the 911 switch I would suggest that you add a relay kit at the headlights. That takes the amp load off the 911 switch and makes it last much longer. This kit makes it easy: http://www.allzim.com/store/zim-s-12v-brig...ategory_id=1127 All you have to do is to extend the 12V wires. I have them fused, and I ran them all the way to the battery. If you need help with the wiring, let me know. I can make diagrams for you on how to change stuff like this. Clay that would be super helpful .. I am just wading my way through this.. |
ClayPerrine |
What relay would this be? Seat belt interupter? Seat belt interlock would be under the passenger seat. The wire colors for that look like a High/Low beam dimmer relay. Ok that helps as well.. As I figure out the 911 switch conversion.. If you are using a 911 turn signal switch, you don't need the relay. The /4 turn signal switch is a momentary contact switch to trigger the relay. The 911 switch is a push/pull switch that wires directly into the headlight circuit. With the 911 switch I would suggest that you add a relay kit at the headlights. That takes the amp load off the 911 switch and makes it last much longer. This kit makes it easy: http://www.allzim.com/store/zim-s-12v-brig...ategory_id=1127 All you have to do is to extend the 12V wires. I have them fused, and I ran them all the way to the battery. If you need help with the wiring, let me know. I can make diagrams for you on how to change stuff like this. Clay that would be super helpful .. I am just wading my way through this.. I need the year of the 914, and the part number off the 911 switch. I will give you two diagrams, and a step by step set of instructions on how to do it. Clay |
mb911 |
Ok will do.. Maybe a day or so.
mrholland2 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 761 Joined: 7-September 11 From: Santa Maria,CA Member No.: 13,531 Region Association: Central California ![]() |
mb911 |
What relay would this be? Seat belt interupter? Seat belt interlock would be under the passenger seat. The wire colors for that look like a High/Low beam dimmer relay. Ok that helps as well.. As I figure out the 911 switch conversion.. If you are using a 911 turn signal switch, you don't need the relay. The /4 turn signal switch is a momentary contact switch to trigger the relay. The 911 switch is a push/pull switch that wires directly into the headlight circuit. With the 911 switch I would suggest that you add a relay kit at the headlights. That takes the amp load off the 911 switch and makes it last much longer. This kit makes it easy: http://www.allzim.com/store/zim-s-12v-brig...ategory_id=1127 All you have to do is to extend the 12V wires. I have them fused, and I ran them all the way to the battery. If you need help with the wiring, let me know. I can make diagrams for you on how to change stuff like this. Clay that would be super helpful .. I am just wading my way through this.. I need the year of the 914, and the part number off the 911 switch. I will give you two diagrams, and a step by step set of instructions on how to do it. Clay @ClayPerrine I found the original ads for the switches I have. The chassis harness is a 74 914.. Let me know if this helps. ![]() ![]() |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,196 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
ClayPerrine |
What relay would this be? Seat belt interupter? Seat belt interlock would be under the passenger seat. The wire colors for that look like a High/Low beam dimmer relay. Ok that helps as well.. As I figure out the 911 switch conversion.. If you are using a 911 turn signal switch, you don't need the relay. The /4 turn signal switch is a momentary contact switch to trigger the relay. The 911 switch is a push/pull switch that wires directly into the headlight circuit. With the 911 switch I would suggest that you add a relay kit at the headlights. That takes the amp load off the 911 switch and makes it last much longer. This kit makes it easy: http://www.allzim.com/store/zim-s-12v-brig...ategory_id=1127 All you have to do is to extend the 12V wires. I have them fused, and I ran them all the way to the battery. If you need help with the wiring, let me know. I can make diagrams for you on how to change stuff like this. Clay that would be super helpful .. I am just wading my way through this.. I need the year of the 914, and the part number off the 911 switch. I will give you two diagrams, and a step by step set of instructions on how to do it. Clay @ClayPerrine I found the original ads for the switches I have. The chassis harness is a 74 914.. Let me know if this helps. ![]() ![]() Ok. Give me a week or so to put together a diagram. Clay |
mb911 |
What relay would this be? Seat belt interupter? Seat belt interlock would be under the passenger seat. The wire colors for that look like a High/Low beam dimmer relay. Ok that helps as well.. As I figure out the 911 switch conversion.. If you are using a 911 turn signal switch, you don't need the relay. The /4 turn signal switch is a momentary contact switch to trigger the relay. The 911 switch is a push/pull switch that wires directly into the headlight circuit. With the 911 switch I would suggest that you add a relay kit at the headlights. That takes the amp load off the 911 switch and makes it last much longer. This kit makes it easy: http://www.allzim.com/store/zim-s-12v-brig...ategory_id=1127 All you have to do is to extend the 12V wires. I have them fused, and I ran them all the way to the battery. If you need help with the wiring, let me know. I can make diagrams for you on how to change stuff like this. Clay that would be super helpful .. I am just wading my way through this.. I need the year of the 914, and the part number off the 911 switch. I will give you two diagrams, and a step by step set of instructions on how to do it. Clay @ClayPerrine I found the original ads for the switches I have. The chassis harness is a 74 914.. Let me know if this helps. ![]() ![]() Ok. Give me a week or so to put together a diagram. Clay Thanks so much @ClayPerrine |
ClayPerrine |
I have the low/high beam and horn wiring mods figured out.
Now I have to look at how to hook up the turn signal wiring. I am actually trying to locate the hand drawn diagrams I made when I did my car. Clay |
mb911 |
I have the low/high beam and horn wiring mods figured out. Now I have to look at how to hook up the turn signal wiring. I am actually trying to locate the hand drawn diagrams I made when I did my car. Clay That is no problem.. My biggest issue is I didn't own this car when it was running as it was a basket case so trying yo figure out what was modified has been a challenge.. Let alone a left hand igniton swap in the middle of the 6 conversion. |
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,185 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
ClayPerrine |
Lo-Fi Version | Time is now: 4th July 2025 - 08:34 PM |
