Ignition timing, Ignition timing confusion |
aeginc77 |
Jul 21 2020, 08:05 AM
Newbie Group: Members Posts: 19 Joined: 29-April 15 From: United States Member No.: 18,682 Region Association: None |
Help! I have never timed my 914 before. I changed the points to electronic ignition and have got a very fast idle. I am prepared with my timing light to check the timing but am confused. I see the v on the impeller shroud and have located the white dot on the impeller ( I assume when both of these are lined up #1 piston is at TDC). I also have a template thanks to Pelican Parts to mark 27degrees before TDC. Do I mark 27 degrees on the shroud where the v is or mark the impeller? I would assume I would see the white dot on the impeller at 27 degree mark marked on the shroud when the timing light flashes. Or do I mark the impeller at 27 degrees BTDC and see the flash at the v on the shroud? I thought I had this until I saw a picture on Pelican Parts of an impeller with a 27 degree mark on the impeller.
GregAmy |
Jul 21 2020, 08:10 AM
Advanced Member Group: Members Posts: 2,311 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
michael7810 |
Jul 21 2020, 10:12 AM
Senior Member Group: Members Posts: 1,081 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
Mark the 27* on the impeller. Set timing at 3,000+ rpm with any vacuum hoses disconnected from the distributor.
dr914@autoatlanta.com |
Jul 21 2020, 02:28 PM
914 Guru Group: Members Posts: 7,893 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
the fan should have the red mark for 27 btdc at the back of the fan and show up when the engine is running at 3500 with the advance disconnected. the mark is just to the right of the big thick reinforcement. Remember spark wire number 1 left drivers rear. There is also a clear picture in the book 914 "tech tips 700"
Help! I have never timed my 914 before. I changed the points to electronic ignition and have got a very fast idle. I am prepared with my timing light to check the timing but am confused. I see the v on the impeller shroud and have located the white dot on the impeller ( I assume when both of these are lined up #1 piston is at TDC). I also have a template thanks to Pelican Parts to mark 27degrees before TDC. Do I mark 27 degrees on the shroud where the v is or mark the impeller? I would assume I would see the white dot on the impeller at 27 degree mark marked on the shroud when the timing light flashes. Or do I mark the impeller at 27 degrees BTDC and see the flash at the v on the shroud? I thought I had this until I saw a picture on Pelican Parts of an impeller with a 27 degree mark on the impeller. |
Wyvern |
Jul 30 2020, 06:33 PM
Member Group: Members Posts: 324 Joined: 7-October 15 From: San Francisco (East Bay) Member No.: 19,245 Region Association: Northern California |
I am going to guess that you installed pertronix ... ?
I know when I did mine there was interference with the mounting plate with a nub on the dizzy. I had to file just a small notch in that plate . Will look for a photo and there was a thread here that mentioned this . |
Wyvern |
Jul 30 2020, 07:08 PM
Lo-Fi Version | Time is now: 7th June 2024 - 04:16 AM |
