Valve adjustment 1.8, Double checking the process |
Mcraneiowa |
Jan 9 2021, 02:46 PM
Member Group: Members Posts: 82 Joined: 16-June 20 From: IA Member No.: 24,387 Region Association: None |
Hey guys, I know this had been hashed over before but want to make clear in my mind a couple things. I previously adjusted the valves base solely on position of distributor rotor. Now weeks later double checking and they don’t seem close enough for my liking, to much play in some cases, not enough in others. So since I have the tranny removed from engine I have a better opportunity to be more precise. So to better understand.
1.8 liter intake .006 exhaust .008. 1974 - When I have the flywheel at TDC based on the mark and confirming it with the position of the distributor rotor pointing towards front center of engine I can adjust #1 cylinder also the tick mark which is about 7degrees off from TDC on the cooling fan mark. - As I rotate flywheel counterclockwise 180 degrees that should line me up with #2. In essence 180 degrees flywheel = 90 degrees distributor. Position is when I rotate the flywheel counterclockwise the dist should turn clockwise, correct. In other words #2 rotor position is pointing towards the oil cooler. So at long as I have flywheel marked, every 180 rotation places me in order for adjusting cylinders In order of 1432. |
ndfrigi |
Jan 9 2021, 02:51 PM
Advanced Member Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
Mcraneiowa |
Jan 9 2021, 03:26 PM
Thanks much for the information. The Pelican article answered my questions completely. Really appreciate the response.
ClayPerrine |
Jan 9 2021, 08:36 PM
Life's been good to me so far..... Group: Admin Posts: 15,526 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
.006 both intake and exhaust https://www.pelicanparts.com/techarticles/9...alve_adjust.htm http://www.914world.com/bbs2/index.php?showtopic=28758 (IMG:style_emoticons/default/agree.gif) The valve clearance for a 1.8 is a typo in the Haynes manual. |
Robarabian |
Jan 9 2021, 10:45 PM
914 A Roo Group: Members Posts: 592 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California |
Never just rely on distributor. Always look at valves to determine where you are on the stroke.
Lo-Fi Version | Time is now: 12th June 2024 - 05:10 AM |
