Morph914 |
Member ![]() ![]() Group: Members Posts: 435 Joined: 22-August 16 From: St Augustine, FL Member No.: 20,326 Region Association: South East States ![]() ![]() |
This is the 914 Rubber outer window fuzzy sealing strip. When I went to replace the old piece with the new one I realized that it is much less substantial and it does not stay in the aluminum track.
Do they make an early and a late part? I just looked on the website and it only shows one of these, so not sure if this is going to work or not. On the site it also says they come predrilled, but I don’t see any holes in them. Has anyone else had issues with these? Are you supposed to drill through the fuzzy strip to install the 3 screws. Very frustrated if this is truly the replacement part. (IMG:style_emoticons/default/headbang.gif) Any help is appreciated. John ![]() Backside of the strip ![]() Inserted into the track ![]() |
aturboman |
Member ![]() ![]() Group: Members Posts: 150 Joined: 18-October 11 From: CA Member No.: 13,687 Region Association: None ![]() |
Hi John Porsche does list different aluminum channels and seals for early cars with cable window regulators 1970-72 vs the the late arm style regulators 1973-76.
I bought Genuine Porsche seals for my early 914-6 restoration and they were extremely tight fitting in the tracks and also did have the screw holes already punched. Not sure what year your car is but that may be the issue? |
914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,294 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
I had the same experience (IMG:style_emoticons/default/sad.gif)
Wasnt worth the hassle sending them back, so I binned them. still available new 914.531.957.10 |
Morph914 |
Hi John Porsche does list different aluminum channels and seals for early cars with cable window regulators 1970-72 vs the the late arm style regulators 1973-76. I bought Genuine Porsche seals for my early 914-6 restoration and they were extremely tight fitting in the tracks and also did have the screw holes already punched. Not sure what year your car is but that may be the issue? Mine is a ‘73, I’ll have to check on that. Thank you |
Morph914 |
I had the same experience (IMG:style_emoticons/default/sad.gif) Wasnt worth the hassle sending them back, so I binned them. still available new 914.531.957.10 Perfect, I think I will do the same thing. Thank you |
Tbrown4x4 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 707 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None ![]() ![]() |
I also have a '73. Fuzzys were too loose in the tracks. I bought OEM and they were too tight. Ended up using Marks, but I'll figure out a way to use the OEM someday.
914werke |
Jett |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,684 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest ![]() ![]() |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,249 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
$58.56 for 1 or a pair?
Tbrown4x4 |
I bought OEM and they were too tight. That's where I'm going with this. I needed the door back together quickly, so I haven't taken the time to bend the fuzzys. |
Morph914 |
Thanks guys, I think I’m going to buy the OEM units.
I have bought a ton of product from 914 Rubber and most of it is good, these strips are not acceptable to me. I’ll be sending back. |
pfreiburger |
Member ![]() ![]() Group: Members Posts: 127 Joined: 6-October 20 From: Fond du Lac, WI Member No.: 24,738 Region Association: None ![]() ![]() |
I just replaced all of the window seals on the drivers door on my 1973. My 1st set of outer fuzzy strips were aftermarket ones from Auto Atlanta and I suspect that they use the same source as 914 Rubber as they fell out of the aluminum track as well. I exchanged them for OEM Porsche items, which fit nice after crowning them a bit. My success rate with aftermarket parts is better than 50%, but probably not much better.
Lo-Fi Version | Time is now: 11th July 2025 - 03:56 AM |
