Best way to run a power wire..., ...from battery to console area? |
Rick986 |
Oct 27 2021, 03:08 PM
0-60 in 14 seconds! Group: Members Posts: 141 Joined: 31-August 21 From: NE Ohio Member No.: 25,869 Region Association: Upper MidWest |
Upgraded my speakers to Infinity Kappa 62IX mounted in 914 Rubber's pods. Massive upgrade in sound...but would still like a little more low-end "punch". I'm going to install a Recoil SL1708 subwoofer inside the console cavity (no holes in console, it just sits inside there!) and need to run a power wire.
What is the "easiest" way to get this through the car? Sorry if this is a silly question but I haven't messed with any electrical stuff yet and can't see how the current wires from the battery enter the vehicle. Seems like they come in behind the seats so maybe there's some kind of "sealed" pass-thru through the firewall? My lift is not in yet so I have somewhat limited access to the bottom of the car and would rather not take the seats out if I don't have to! Thanks! - Rick |
euro911 |
Oct 27 2021, 03:23 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,849 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
There's a rubber snorkel that the OEM wiring runs through the tunnel and is routed up through the panel in front if the motor into the engine compartment.
It isn't an easy task to introduce additional wires through the snorkel, especially large-gauge high-current carrying conductors ... See this thread ... and this one You may need to drill an additional hole and install a rubber grommet in the firewall to get from the battery location into the tunnel and up to the console area, or wherever you plan to mount the power amp/sub woofer. That's what I did when running a 2-conductor 10AWG siamese power cable for a two-way radio that I installed in my '75. (IMG:style_emoticons/default/confused24.gif) |
Puebloswatcop |
Oct 27 2021, 03:29 PM
Senior Member Group: Members Posts: 1,389 Joined: 27-December 14 From: Mineola, Texas Member No.: 18,258 Region Association: Southwest Region |
Upgraded my speakers to Infinity Kappa 62IX mounted in 914 Rubber's pods. Massive upgrade in sound...but would still like a little more low-end "punch". I'm going to install a Recoil SL1708 subwoofer inside the console cavity (no holes in console, it just sits inside there!) and need to run a power wire. What is the "easiest" way to get this through the car? Sorry if this is a silly question but I haven't messed with any electrical stuff yet and can't see how the current wires from the battery enter the vehicle. Seems like they come in behind the seats so maybe there's some kind of "sealed" pass-thru through the firewall? My lift is not in yet so I have somewhat limited access to the bottom of the car and would rather not take the seats out if I don't have to! Thanks! - Rick Hi Rick, The bad news is that the power supply wires go into the interior of the car through the main wiring harness through the snorkle tube and then run along the tunnel up under the dash. If you are looking to run a power wire to the sub woofer, I would look at running off of the fuse panel so that it is a protected circuit. Kevin |
bbrock |
Oct 27 2021, 04:36 PM
With the engine out I was able to pull an 8 gauge wire through the harness snorkel surprisingly easy by fishing a wire through first and then pulling the cable. I put off the job for months thinking it was going to be a giant PITA, but it took less than 20 minutes to get the job done. Having the engine out lets you pull the harness down so the snorkel is somewhat straight to make fishing and pulling doable.
Rick986 |
Oct 28 2021, 09:52 AM
Hey Kevin - Thanks for the response...but how do you "run it off the fuse box"? Just tap it into one of the empty circuits? (I think I have a couple).
If you'd rather PM me, I'd appreciate it. Thanks! Upgraded my speakers to Infinity Kappa 62IX mounted in 914 Rubber's pods. Massive upgrade in sound...but would still like a little more low-end "punch". I'm going to install a Recoil SL1708 subwoofer inside the console cavity (no holes in console, it just sits inside there!) and need to run a power wire. What is the "easiest" way to get this through the car? Sorry if this is a silly question but I haven't messed with any electrical stuff yet and can't see how the current wires from the battery enter the vehicle. Seems like they come in behind the seats so maybe there's some kind of "sealed" pass-thru through the firewall? My lift is not in yet so I have somewhat limited access to the bottom of the car and would rather not take the seats out if I don't have to! Thanks! - Rick Hi Rick, The bad news is that the power supply wires go into the interior of the car through the main wiring harness through the snorkle tube and then run along the tunnel up under the dash. If you are looking to run a power wire to the sub woofer, I would look at running off of the fuse panel so that it is a protected circuit. Kevin |
slivel |
Oct 28 2021, 10:29 AM
Old car....... older driver Group: Members Posts: 510 Joined: 10-July 04 From: San Diego Member No.: 2,332 Region Association: Southern California |
Be sure to include an appropriately sized fuse at the battery end. Without it, if the insulation ever rubbed through or got cut you may have some unscheduled welding going on in your car.
Shown is the fuse for the power wire to the power amps in my van. |
bbrock |
Oct 28 2021, 10:58 AM
Be sure to include an appropriately sized fuse at the battery end. Without it, if the insulation ever rubbed through or got cut you may have some unscheduled welding going on in your car. Shown is the fuse for the power wire to the power amps in my van. (IMG:style_emoticons/default/agree.gif) You need to look at the power and wire gauge requirements of your powered sub or amplifier to run the sub and make sure you aren't trying to pull more current from the fuse box than it can handle. Making bass takes power so usually you run a heavy gauge wire from the battery with a heavy duty inline fuse. It all depends on your equipment needs though. My amp is not huge and requires a 40 amp fuse and 8 gauge cable. You aren't going to be able to connect that to the vehicle fuse box. |
windforfun |
Oct 28 2021, 12:00 PM
Senior Member Group: Members Posts: 1,809 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Add a Pi filter just before the sub to eliminate alternator noise.
Puebloswatcop |
Oct 28 2021, 03:28 PM
Hey Kevin - Thanks for the response...but how do you "run it off the fuse box"? Just tap it into one of the empty circuits? (I think I have a couple). If you'd rather PM me, I'd appreciate it. Thanks! Upgraded my speakers to Infinity Kappa 62IX mounted in 914 Rubber's pods. Massive upgrade in sound...but would still like a little more low-end "punch". I'm going to install a Recoil SL1708 subwoofer inside the console cavity (no holes in console, it just sits inside there!) and need to run a power wire. What is the "easiest" way to get this through the car? Sorry if this is a silly question but I haven't messed with any electrical stuff yet and can't see how the current wires from the battery enter the vehicle. Seems like they come in behind the seats so maybe there's some kind of "sealed" pass-thru through the firewall? My lift is not in yet so I have somewhat limited access to the bottom of the car and would rather not take the seats out if I don't have to! Thanks! - Rick Hi Rick, The bad news is that the power supply wires go into the interior of the car through the main wiring harness through the snorkle tube and then run along the tunnel up under the dash. If you are looking to run a power wire to the sub woofer, I would look at running off of the fuse panel so that it is a protected circuit. Kevin Hello again Rick, I got to thinking about it last night and it would really depend on how much power it pulling. It might be better to run it stright off the battery as it probably will require more amps than you will have at the fuse panel. While it is a PITA to run the wire through the snorkel, it is doable just be vrey patient and plan on spending a day to do it. You'll need a wire to push through from the interior of the cat and then use wire lube to get everything back through. Just make sure you put an in line fuse near the battery so if something were to short it won't fry your wiring harness. I'm just not sure the old fuse panel has any available amperage to drive a modern Sub like the one you are installing |
Shivers |
Oct 29 2021, 02:59 PM
Senior Member Group: Members Posts: 2,408 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Keep everything out of the cabin that you can. Leave the stock wiring system alone. It is not designed to add a high amp draw. Extra lights, amps whatever. Straight from the battery to a fuse block, to a relay. Low voltage switch leg goes inside for lights. Keep the electrical fires outside.
Lo-Fi Version | Time is now: 29th May 2024 - 05:07 AM |
