tubing for windshield washer bottle |
hndyhrr |
Nov 17 2021, 07:49 PM
Senior Member Group: Members Posts: 555 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest |
Does anyone sell the hose/tubing that goes from the windshield washer bottle across and into dash and then into steering assembly? Is this something I can get local? If so any particular size, thickness etc. Thanks |
L-Jet914 |
Nov 17 2021, 11:13 PM
Member Group: Members Posts: 250 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California |
Does anyone sell the hose/tubing that goes from the windshield washer bottle across and into dash and then into steering assembly? Is this something I can get local? If so any particular size, thickness etc. Thanks I recently replaced my washer fluid hoses from the bottle to the wiper stalk and then back out one way check valves and finally to the washer jets. I used washer fluid hose for a 2018 Toyota CH-R that I ordered from my local dealer. It was the right amount with some left over. Price was decent for almost 7 feet of hose. The OD of the hose is thicker and more robust than stock but fits perfectly on the connections. It was a little tricky getting the hose through the front firewall grommet, so I used some Silglyde to help it through the grommet. I can get the part number if you like. Be very careful removing the hose from the windshield wiper stalk as the fittings are plastic. I very carefully cut off the old hose from the washer fittings at the column. |
Jett |
Nov 18 2021, 11:00 AM
Senior Member Group: Members Posts: 1,640 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
914Rubber sells the hose kit
IronHillRestorations |
Nov 18 2021, 12:08 PM
I. I. R. C. Group: Members Posts: 6,727 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I had to get several other things from Porsche so I got that too, and it was perfect
hndyhrr |
Nov 18 2021, 06:00 PM
L-Jet914 |
Nov 19 2021, 12:24 AM
I had to get several other things from Porsche so I got that too, and it was perfect Would you have the part number for the washer tubing as 914 rubber is out of stock right now. thnaks OEM superseded part number from Porsche shows PCG-628-901-10. Sold in 3 meter lengths and it looks like clear hose. I used the Toyota hose as it was black rubber like the OEM hose I had in my 914. Grant it, the hose was a little larger in diameter. |
Nov 19 2021, 06:42 AM
I was working on a 6, which is totally different. Go with the 914 rubber hose
Lo-Fi Version | Time is now: 5th June 2024 - 08:20 AM |
