914-6 with Zenith? |
DennisV |
Jul 18 2022, 03:53 PM
Member Group: Members Posts: 484 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California |
Did any 914-6 engine come original with Zenith carbs?
When I look at the Porsche 914 Factory Parts Catalogue, it appears to list only two carburetor part numbers (left and right) which are 40 IDT Weber. We acquired an engine that is 914-6 correct number range, but has Zenith 40 TIN on it. Is there any chance they are correct? I'm guessing someone just didn't care about originality, and threw them on there. Thank you. |
brant |
Jul 18 2022, 04:05 PM
914 Wizard Group: Members Posts: 11,635 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Nope
Only came with webers Someone in the past put those on |
914Sixer |
Jul 18 2022, 04:56 PM
914 Guru Group: Members Posts: 8,901 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Zenith 40 TIN came on 911 T motor. They were German made. Depending on who you talk to they were a better carb than the Webers. Not as finicky and easier to maintain.
DennisV |
Jul 19 2022, 08:15 PM
Zenith 40 TIN came on 911 T motor. They were German made. Depending on who you talk to they were a better carb than the Webers. Not as finicky and easier to maintain. Do you have to do anything special to get the Zenith to work correctly in a 914-6? Other than the carbs, did anything make a 914-6 engine different than a 911T? |
brant |
Jul 20 2022, 05:51 AM
Zeniths we’re sold originally on a 2.2 motor
The venturis are appropriate for a small bore engine They may need to be re jeted but depending on altitude and use The 914/6 was actually the least special motor from Porsche Most but not all Weber parts should work Including gaskets I believe I don’t think zenith parts are available so using or modifying Weber parts is the only option |
Optimusglen |
Jul 20 2022, 08:55 AM
Senior Member Group: Members Posts: 912 Joined: 26-February 16 From: Minneapolis Member No.: 19,709 Region Association: Upper MidWest |
Zeniths we’re sold originally on a 2.2 motor The venturis are appropriate for a small bore engine They may need to be re jeted but depending on altitude and use The 914/6 was actually the least special motor from Porsche Most but not all Weber parts should work Including gaskets I believe I don’t think zenith parts are available so using or modifying Weber parts is the only option The '71 911T was a 2.2 with Zeniths from the factory. I have that motor and those carbs in my 914. At an elevation of 900ft I'm running 30mm venturis, #55 idle jets, and #130 main jets. This was ok even up to higher elevations (~9000ft) on a trip last year, but of course, it was rich at higher elevations and slow. I never had Webers, but everything lined up just fine. |
BK911 |
Jul 20 2022, 09:07 AM
Senior Member Group: Members Posts: 672 Joined: 19-February 04 From: Rocky Top, TN Member No.: 1,674 Region Association: None |
Intake manifold is the same.
Nothing else is. Dude on ebay Alfa??? sells vents and jets. Zeniths also came on euro 2.4Ts. |
nditiz1 |
Jul 21 2022, 05:02 AM
Senior Member Group: Members Posts: 1,191 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
I'm running them on my 2.4T. I have recently purchased from that ebay seller twice with good results.
Root_Werks |
Jul 21 2022, 10:06 AM
Village Idiot Group: Members Posts: 8,333 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
If I remember correctly, there are a number of Solex parts that work in Zenith carbs. I remember using Zeniths on a number of 914-6 conversions and they worked well. Used Solex jets and other bits, maybe even venturies? Local VW speed shop at the time stocked bunch of Solex stuff that worked.
porschetub |
Jul 21 2022, 02:55 PM
Advanced Member Group: Members Posts: 4,704 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Intake manifold is the same. Nothing else is. Dude on ebay Alfa??? sells vents and jets. Zeniths also came on euro 2.4Ts. Have dealt with that seller for Zenith parts from the get go,the service,shipping and quality is top notch,they make all the real hard parts now,my last purchase was a set of throttle lever cams,really well made. Last time I looked on there they had pretty much anything you need,while back I needed parts not listed and they supplied them. When all the parts for these dried up no one wanted them as about the only thing you could buy was the gasket sets (@ a price ), they earned a bad rep for this reason. |
Lo-Fi Version | Time is now: 6th June 2024 - 06:29 AM |
