| 76-914 |
Sep 30 2022, 11:53 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,962 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
You can email the pics to yourself then adjust the size before posting. Also, Apples latest release of Monterey allows you to convert their pic's to a lower quality JPG file. (IMG:style_emoticons/default/beerchug.gif)
| DennisV |
Oct 1 2022, 07:01 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,029 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
If you are on Mac OS, Preview has an easy to use mechanism for changing images sizes and gives you quite a bit of control. I believe it is the default image viewer on Mac. If you have the photo open select the following from the menu bar
Tools > Adjust size... You'll get this window. Keep Scale proportionally checked. Depending on the level of detail you need to display, enter something like 600 for a width or height value. The other will value update automatically to maintain proportions. Setting your Resolution to 72 is usually a good choice for screen images. ![]() |
| sixaddict |
Oct 1 2022, 07:25 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,085 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States
Thanks guys….let me have my resident tech “expert” give suggestions a try.
| sixaddict |
Oct 1 2022, 08:03 AM
So we only use I pad….Monterrey only available for I Mac
Still searching for solution |
| sixaddict |
Oct 1 2022, 08:24 AM
Got an app (IMG:style_emoticons/default/beer.gif)
| TheCabinetmaker |
Oct 4 2022, 01:47 PM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,378 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
What is the preferred size for here?
| davep |
Oct 4 2022, 08:21 PM
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,376 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
I have used IRFANVIEW for 20 years. Great for editing, resizing, color correction, and format conversion. Even can autocorrect file type if incorrect. Not much I do not use it for.
| Montreal914 |
Oct 5 2022, 07:57 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,192 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California
MS Paint: Open, resize and/or crop to remove the extra junk that is part of the picture (IMG:style_emoticons/default/rolleyes.gif), save or "save as" if you want to keep your original, done.
Will also solve the pictures in wrong orientation. (IMG:style_emoticons/default/beerchug.gif) ...I know MAC are more pleasant to work with, but when it comes to using CAD like SolidWorks or NX, there is just no way... Edit: size? I typically do about 300-400KB |
| drem914 |
Oct 6 2022, 09:08 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,080 Joined: 16-May 08 From: Trabuco Canyon, CA Member No.: 9,062 Region Association: Southern California
MS Paint: Open, resize and/or crop to remove the extra junk that is part of the picture (IMG:style_emoticons/default/rolleyes.gif), save or "save as" if you want to keep your original, done. Will also solve the pictures in wrong orientation. (IMG:style_emoticons/default/beerchug.gif) ...I know MAC are more pleasant to work with, but when it comes to using CAD like SolidWorks or NX, there is just no way... Edit: size? I typically do about 300-400KB (IMG:style_emoticons/default/agree.gif) |
| mmichalik |
Oct 6 2022, 12:05 PM
MikeM ![]() ![]() ![]() Group: Members Posts: 804 Joined: 27-January 16 From: Valley Center, CA Member No.: 19,600 Region Association: Southern California
www.compressjpg.com will reduce size. You upload the file, it compresses it for you (usually about 30-40%) and then you download it.
It will compress most file types, even though the name is compressjpg.com |
Lo-Fi Version | Time is now: 12th September 2026 - 08:33 AM |
