> Six conversion question
sixaddict
post Dec 13 2022, 04:47 PM
Here’s an easy one
When converting a 4 to a 6 is it necessary to use six relay board.
Thanks
Replies(1 - 10)
post Dec 13 2022, 05:04 PM
914-6 GT in waiting
Nope
Actually it’s not always necessary to use one at all.
sixaddict
post Dec 13 2022, 05:15 PM
Thanks Mark
JmuRiz
post Dec 13 2022, 09:24 PM
I think Perry still does custom harnesses for whatever board or no-board you want to run:
http://www.914world.com/bbs2/index.php?showtopic=24228
Still on my to-buy list
post Dec 13 2022, 09:51 PM
Resident German
QUOTE(mepstein @ Dec 13 2022, 03:04 PM) *
Nope
I removed mine completely and used a PMS adapter harness which plugs in directly to the /4 main chassis harness and goes to the /6 engine.
post Dec 13 2022, 11:22 PM
914-6 GT in waiting
QUOTE(SirAndy @ Dec 13 2022, 10:51 PM) *
Nope
Did the same on my 3.2. Easy peasy.
Retroracer
post Dec 13 2022, 11:45 PM
Another option is to retain the -4 relay board / cover, if you're after more of an original look and you're swapping in a period correct 6 (requiring an external voltage regulator). Just need an engine harness to match up to the connector.
- Tony
mlindner
post Dec 14 2022, 05:26 AM
Not only does Perry build a great engine harness, he also explains it well. Plug and play.Attached Image Attached Image
dr914@autoatlanta.com
post Dec 14 2022, 09:29 AM
no not at all and very very cost prohibitive.
I in my pamphlet 914-6 conversion guide or "what you are getting yourself into" have the wiring harness diagrams showing how to use the four board with a six engine
QUOTE(sixaddict @ Dec 13 2022, 03:47 PM) *
Here’s an easy one
Thanks
Steve
post Dec 15 2022, 09:03 PM
Typically not needed with a six and I removed mine.
From what I remember, what's on the board?
1. Fuel pump connection. With my 2.7 it was easier to wire up a separate fuse for the fuel pump. 3.2 and 3.6 fuel injection have separate connections for this anyway.
2. Heater fan relay. Not needed with a six conversion
3. Regulator. Most sixes already have a built in regulator
4. 914-4 Fuel injection. Not needed
5. ? Rear window defogger. Does yours have one? Either keep the board or rewire it.
Root_Werks
post Dec 16 2022, 10:26 AM
Village Idiot
QUOTE(mepstein @ Dec 13 2022, 09:22 PM) *
Nope
Similar on mine, removed the relay board and brackets. Makes it nicer to access oil tank stuff.
- Lo-Fi Version Time is now: 3rd November 2026 - 09:38 PM
