Side Mirrors on Wing Window, Whats worked best ? |
jim_hoyland |
Aug 14 2005, 09:24 PM
Get that VIN ? Group: Members Posts: 9,306 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Been leaning toward using side mirrors that attache dto the triangular front glass. Want mirror as big a 911--must clear the post.
Did see a very nice pair on a Fer ? Any pictures / suggestions will be appreciated Attached image(s) |
ArtechnikA |
Aug 15 2005, 06:41 AM
DON'T TRY TO DRILL THE GLASS!
place your faith in glue. i've wondered if an A-pillar mount (a la new Testarossa) would work. i like the wing window mount in concept but i like that they open, so i'm stuck with other alternatives. the 911 flag mirror is more period corrent for my car anyway... |
jim_hoyland |
Aug 15 2005, 08:04 AM
Allen, do you have a picture of the mirrors we talked about Saturaday in San P ?
MoveQik |
Aug 15 2005, 08:46 AM
What size wheels can I fit? Group: Members Posts: 4,645 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
Your wing windows open??? Or did I read that wrong? |
ArtechnikA |
Aug 15 2005, 08:54 AM
prolly shouldda mentioned: 911. sorry about the confusion... |
MoveQik |
Aug 15 2005, 09:06 AM
Nevermind..... |
Allan |
Aug 16 2005, 03:19 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
Here's a pic of one style I liked. I'm trying to find the other pics. Attached image(s) |
Allan |
Other side
Attached image(s) |
flesburg |
Aug 16 2005, 04:12 PM
Senior Member Group: Members Posts: 506 Joined: 22-November 04 From: Pontiac, IL Member No.: 3,162 |
I fabricated the mounts and used a 3M tape to hold them to the glass. Anything much bigger might be a problem.
Attached thumbnail(s) |
jim_hoyland |
Aug 16 2005, 04:31 PM
Nice; do the posts block the view ?
flesburg |
Aug 16 2005, 06:54 PM
The drivers side is okay, but the passenger side give a pretty limited view. I have a 5 panel wink on the inside, and overall have good rearward vision.
I just like the way they look. The little mirrors are made by the some co that makes tornado (sp?) mirrors, and they are cheap, under $20 each. They took a lot of time to make however. The bases are cut out of 1/4" thick plexiglass, sanded and shaped and painted. The mirrors screw to the bases, and then the bases were taped to the window. More of an unusual look that anything else I have seen, and if you do not like them, no big $ loss. |
pjhaun |
Aug 17 2005, 10:39 PM
Member Group: Members Posts: 370 Joined: 21-August 03 Member No.: 1,055 Region Association: None |
Here is a picture of my car with BMW M3 mirrors attached to wing window with silicone.
Attached image(s) |
Bee Jay |
Aug 17 2005, 11:46 PM
Member Group: Members Posts: 204 Joined: 22-April 05 From: Lompoc, Ca. Member No.: 3,964 |
I bought pexiglass vent windows and mounted M3 replicas. Check it out here: http://www.picturetrail.com/gallery/view?p...2754&uid=598455
Bee Jay |
Rough_Rider |
Aug 18 2005, 09:43 AM
Smurf Zone Group: Members Posts: 525 Joined: 16-August 04 From: Beaverton, OR Member No.: 2,547 |
Don't have a pic on my work machine.
I made some plexiglass windows, takes about 20 minutes per side. Drilled them & mounted some carbon fiber formula mirrors, from SPA. Vision is adequate, fiddly to adjust as there's individual screws for each axis. Looks cool though & the whole things is extremly light. |
STL914 |
Aug 18 2005, 10:19 AM
Senior Member Group: Members Posts: 1,180 Joined: 22-October 03 From: O'Fallon, MO Member No.: 1,271 Region Association: Upper MidWest |
Is that a sun roof in the targa top? And do you have a trailer hitch mounted in the car? |
jim_hoyland |
Aug 18 2005, 10:22 AM
How much surface area is holding those to the glass ? Nice!!!
pjhaun |
Aug 18 2005, 12:45 PM
STL914 (Gary): Yes to both questions. I adapted a bike rake to the trailer hitch. The trailer was made in Canada and it is basically designed for a touring motorcycle. |
pjhaun |
Aug 18 2005, 12:56 PM
jim hoyland: I am at work right now; so I will have to measure the mirrors when I get home. But these side mirrors are also break away. When I push on the mirror with so force they will fold back and then spring back. These particular mirrors have turn signals lights in them. I have them wired up for blue turn signal lights. |
jim_hoyland |
Aug 18 2005, 06:29 PM
Thanks: do you still have the model/part number ? Checked the Pelican PArts site, they list ( no pictures) several models.
Got a recommended place to purchase ? Are there good used available ? |
Lo-Fi Version | Time is now: 23rd May 2024 - 12:19 AM |
