| rotary914 |
Aug 15 2005, 11:49 PM
Newbie ![]() Group: Members Posts: 4 Joined: 29-March 05 From: Chandler, Arizona Member No.: 3,838 |
I have a RX-7 with a E6X that is running very well.
I plan to put a rotary engine in my 914, but it is probably 2 years away. I would like to run the 914 - stock 1.7 Liter 4 cyllinder air cooled, type 4 engine - being controlled with the E6X. My stock FI System is tired - it will run much better once it's tuned with the E6X if possible. And then I can keep the same E6X to run the rotary. Has anyone done an air cooled engine with an E6X? Would I somehow use the coolant map for head temperature changes?? Any setup help will be much appreciated Steve |
| Mueller |
Aug 16 2005, 12:36 AM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,157 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
the Haltech does not care if it's water or air cooled....
you should be able to use the stock CHT since most of the Bosch and GM sensors pretty much overlap correctly for fuel enrichment (I'm using the stock CHT with my Link and it works fine)..... The watertemp/CHT is only used while the motor is cold. I know a few aircooled 911 guys with Haltechs and one 914 guy with a Haltech, but he is running a rotary so not much help (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
| Mueller |
Aug 16 2005, 12:51 AM
I do recommend running it MAP+TPS, I was trying to run mine only on MAP (only) and then only on Vacuum (only)and I didn't like the idle qualities, once I installed a TPS it was much better.
You should be able to use all of the stock components except the TPS and depending on the setup of the E6X, you might need ballast resistors for the stock injectors. |
| Mark Henry |
Aug 16 2005, 05:32 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
Most guys mount the temp sensor up under the cylinders.
My SDS is on an almost stock 1.8, runs good. |
| Jeroen |
Aug 16 2005, 06:00 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
I'm sure TimT will chime in
(if not, try contacting him) The shop he's connected to is a Halltech dealer |
| TimT |
Aug 16 2005, 02:40 PM
retired ![]() ![]() ![]() ![]() Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
You rang?
We have installed E6X, E11X on all manner of cars yes you could easily use an E6X to control a 1.7 We actually just finished a Mazda 12B turbo using the E6, it sounds like its making impressive power. Dyno time this week I think Mike mentions you need to change the stock TPS, that should be a snap We use the coolant correction maps for changes in oil temp, hadnt really though about mixture correction on the fly based on cht.. We see very stable egts on our 3.8 turbo engine while under boost, so I dont think basing a correction map on cht is warranted. the coolant maps are basically active only during warmup |
Lo-Fi Version | Time is now: 25th November 2026 - 10:19 PM |
