Front Trunk Cable and Housing Replacement, Who's done the "Back up" release: |
Root_Werks |
Aug 10 2023, 09:36 AM
Village Idiot Group: Members Posts: 8,334 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Last week, pulled the Frunk handle and it pulled further than it normally does. Frunk still opened. Upon inspection, the old plastic housing broke close to the latch.
Fast forward a week and now I have the 914Rubber cable and housing installed (very beefy). Also used the opportunity to rekey the lock to match the rest of the 914 thanks to this link: http://www.914world.com/specs/rekey.php Question, Anyone ever install any sort of backup unlatching system? Cable that runs bellow the spare tire well? Or is it just remove the bumper and use the little hole method? Always thought if the cable failed when it's time to fill the tank...be nice to just reach under and pop the hood rather than dig out the tools and pull the bumper. And yes, I did forget to remove the Frunk stops before the 914 was painted. But everyone's still allowed to razz me about it anyway. (IMG:style_emoticons/default/smile.gif) Attached thumbnail(s) |
Root_Werks |
Aug 10 2023, 09:40 AM
Didn't really see a good place on the latch to attach another cable or wire. I guess anything would pull down instead of to the side meaning it wouldn't work.
My bumper is two large bolts and off it comes. Maybe that's just the backup? Attached image(s) |
NARP74 |
Aug 10 2023, 12:21 PM
Senior Member Group: Members Posts: 1,073 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
Going through this now, waiting for cable sleeve. I have a fiberglass bumper and an oil cooler to get through with bolts in the trunk, just to reach the latch. Might need to get creative, or just roll the dice and pretend it will never happen.
Did you route the cable to the inside or outside of the headlight drain tube? |
FlacaProductions |
Aug 10 2023, 12:32 PM
Senior Member Group: Members Posts: 1,615 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
Root_Werks |
Aug 10 2023, 02:20 PM
Going through this now, waiting for cable sleeve. I have a fiberglass bumper and an oil cooler to get through with bolts in the trunk, just to reach the latch. Might need to get creative, or just roll the dice and pretend it will never happen. Did you route the cable to the inside or outside of the headlight drain tube? Routed the tube behind the headlight bucket. Even had some new cloth braided hose to slide over just the factory. PITA for certain, sure looks like. Old tube had overspray and was yellow/brown mostly in color. |
Root_Werks |
Aug 10 2023, 02:23 PM
See this: http://www.914world.com/bbs2/index.php?s=&...t&p=2713261 and this: http://www.914world.com/bbs2/index.php?s=&...t&p=2713273 Good link, thanks! -Dan |
76-914 |
Aug 10 2023, 03:19 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,508 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Yep, I used SS safety wire (I know you have a spool of that in your hanger) and made a loop on the end (think hangman's noose) with a thick piece of nylon in the loop so I didn't slice my finger when and if pulled it. (IMG:style_emoticons/default/beerchug.gif)
Root_Werks |
Aug 10 2023, 03:37 PM
Yep, I used SS safety wire (I know you have a spool of that in your hanger) and made a loop on the end (think hangman's noose) with a thick piece of nylon in the loop so I didn't slice my finger when and if pulled it. (IMG:style_emoticons/default/beerchug.gif) Yup, have some SS wire around. (IMG:style_emoticons/default/wink.gif) I'll rig up something and post a picture. I like going sideways through the headlight bucket. Simple, hidden.....as I post it on the internet. (IMG:style_emoticons/default/blink.gif) |
worn |
Aug 10 2023, 07:19 PM
can't remember Group: Members Posts: 3,162 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
On a trip to WCR my rear trunk lock failed locked and my wife had to push down on the hood to get the frunk unlatched. I have an extra pull now, but was thanked for not posting photos. Glad to answer PMs with pics though.
Warren |
Matt Romanowski |
Aug 14 2023, 07:11 AM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
Never messed with an extra safety.
When replacing the cable, you don't have to remove the pull handle housing and the (most likely rusted in place). If you remove the stop screw in the bottom of it, you can pull the handle and the cable with it. Change the metal cable, reinsert, connect at the trunk latch, adjust, Bob's your Uncle. |
Lo-Fi Version | Time is now: 7th June 2024 - 08:55 AM |
