Too much oil pressure, causing oil leak? |
MattR |
Aug 18 2005, 02:56 PM
Advanced Member Group: Members Posts: 3,279 Joined: 23-January 04 From: SF Bay Area Member No.: 1,589 Region Association: Northern California |
Question for the type 4 masters out there:
My new 2056 is leaky (~1 qt in 10 mins from the oil cooler seals). I thought it was the seals, so I took those out and tried to seat them properly dozens of times with no luck. Now Im thinking its an oil pressure thing. I plug in my electrical VDO gauge and it pegs it (past 80 psi). I dont THINK my oil pressure relief pistons are stuck. I pulled the plugs and they slid freely in their bores. Are there any other suggestions for too much oil pressure? Im running a shadeck 30mm t1 pump and ive drilled and tapped all my oil galley plugs and cleaned the galleys. Ideas? |
Twystd1 |
Aug 18 2005, 03:04 PM
You don't want to know... really..... Group: Members Posts: 2,514 Joined: 12-September 04 From: Newport Beach, California Member No.: 2,743 |
BUMP....!!!!!
Twystd1 |
Aaron Cox |
Aug 18 2005, 03:08 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
point of reference: i have a similar high flow pump... cold oil PSI at idle is about the same....but my cooler seals dont leak (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
and i have non stuck replacement bleed off pistons.... AA |
MattR |
Aug 18 2005, 04:52 PM
Nevermind...
I hooked up a mechanical gauge and got 60 psi at idle and near 75 at revs. Back to being confused (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) |
SLITS |
Aug 18 2005, 05:10 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
You might start looking for a hairline crack in the cooler / case.
Might be useful to take it off and have it pressure tested or obtain another known good one and refit. |
Aaron Cox |
Aug 19 2005, 12:10 AM
howd it go today matt?
you and clayton knock it out??? |
Lo-Fi Version | Time is now: 16th June 2024 - 12:34 PM |
