123 Distributor Group Buy for November 2023 |
DC_neun_vierzehn |
Oct 20 2023, 10:28 AM
Member Group: Members Posts: 387 Joined: 16-November 20 From: Delaware Shore Member No.: 24,893 Region Association: MidAtlantic Region |
I just talked to Ed at 123 Ignition USA and he's agreed to set up another group buy for 914 World members. He will give us a code that will provide an instant 5% off and then if we 10 people use that code in 30 days everyone will get another 5% refunded (for a total discount of 10%).
I don't want to get that code yet because we'll be on the 30 day clock once he provides it. I'm thinking we could get the code on November 1st. Who would be interested besides me and @FlacaProductions ? |
FlacaProductions |
Oct 20 2023, 11:08 AM
Senior Member Group: Members Posts: 1,607 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
Thanks for being the honcho on this - very nice!
JeffBowlsby |
Oct 20 2023, 11:18 AM
914 Wiring Harnesses Group: Members Posts: 8,524 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
DC_neun_vierzehn |
Oct 20 2023, 01:20 PM
For those that are unfamiliar with 123 there are plenty of threads about the benefits. Here's a recent thread:
http://www.914world.com/bbs2/index.php?showtopic=364592 |
914_teener |
Oct 20 2023, 02:44 PM
914 Guru Group: Members Posts: 5,204 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
I think I did the original group buy on these.
Back then, they only had the switched version for D-jet and blue tooth for carbs. For stock D-jet the switched version ran just fine and for those who don't know "switched" means the curve configurations are (were) hard mapped in the dizzy. So I noticed that there is a considerable price difference between the mappable dizzy and the hard mapped dizzy (switched)..bout $200. Still, I'd say hands down, the best improvement for drivability I ever did on that car. |
Stratfink |
Oct 21 2023, 01:44 AM
Newbie Group: Members Posts: 40 Joined: 27-December 21 From: SoCal Member No.: 26,198 Region Association: Southern California |
I’ve been considering this. The group buy could be the incentive to pull the trigger.
DC_neun_vierzehn |
Oct 21 2023, 08:05 AM
I think I did the original group buy on these. Back then, they only had the switched version for D-jet and blue tooth for carbs. For stock D-jet the switched version ran just fine and for those who don't know "switched" means the curve configurations are (were) hard mapped in the dizzy. So I noticed that there is a considerable price difference between the mappable dizzy and the hard mapped dizzy (switched)..bout $200. Still, I'd say hands down, the best improvement for drivability I ever did on that car. Huge endorsement there "the best improvement for drivability I ever did on that car." @BeatNavy said the same thing - bluetooth option was not available for D-jet when he got his 123, which makes makes setup tricky. Seems like the bluetooth option is a no brainer now. The 123 w/ bluetooth is not cheap ($500-ish), but worth it when you weigh in all of the potential troubleshooting headaches and expenses you'll save yourself from in the future. Just new trigger points (or rebuilt trigger points) alone are nearly 50% of the cost of a 123 w/ bluetooth. |
saigon71 |
Oct 21 2023, 09:02 AM
Advanced Member Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
Count me in for this group buy. Thanks for setting it up. (IMG:style_emoticons/default/beerchug.gif)
aharder |
Oct 21 2023, 11:54 AM
Advanced Member Group: Members Posts: 4,405 Joined: 6-September 11 From: Dallas Texas Member No.: 13,524 Region Association: Southwest Region |
I've been thinking of one for a long time so you can count me in also.
I just need to determine which one, I think it's the BT Tune + Porsche 4-R-V since I'm running Weber 40's and will have the same on my 2056 in progress. |
Front yard mechanic |
Oct 21 2023, 02:58 PM
Senior Member Group: Members Posts: 1,169 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
Jeff everything I read from you regarding 123has been skeptical. Are you now all in? |
Porschef |
Oct 21 2023, 03:40 PM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
If the thought even entered your mind, then just do it. Yes, there are no less expensive alternatives to points and condensers but nothing has made my car run better.
Yeah, the half G is a hit to some, myself included, but the old expression “Buy once, cry once” really applies here. And there’ll be no crying after it’s dialed in. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/smile.gif) |
JeffBowlsby |
Oct 21 2023, 09:05 PM
Jeff everything I read from you regarding 123has been skeptical. Are you now all in? Not skeptical, I think the 123 is technically a good solution. The only concerns I brought up before were related to the djet trigger points connection to the harness. It’s not resolved at all and is a long term problem. I think it needs a new 2 piece watertight quick disconnect connection for mating to the harness, a flexible protective wire covering over the exposed wires, and something to watertight the wiring penetration at the dizzy body. It would be great if 123 would provide this to make their dizzy plug ‘n play. If they would send me a complementary djet dizzy for my 74 914 2.0L djet I could develop a solution. (IMG:style_emoticons/default/wink.gif) |
DC_neun_vierzehn |
Oct 23 2023, 12:36 PM
Looks like we have 5 in so far for the group buy:
1. @FlacaProductions 2. @DC_neun_vierzehn 3. @Stratfink 4. @saigon71 5. @aharder Just need 5 more. |
jim-c |
Oct 23 2023, 02:52 PM
Newbie Group: Members Posts: 20 Joined: 21-November 21 From: Fort Lauderdale Member No.: 26,090 Region Association: South East States |
I had one of these installed on my 2.0 . It worked great . Easy to install, quality piece. I had the Bluetooth model and the ability to adjust timing at various rpm was very helpful .
flipb |
Oct 24 2023, 06:43 AM
Senior Member Group: Members Posts: 1,724 Joined: 2-September 09 From: Fairfax, VA Member No.: 10,752 Region Association: MidAtlantic Region |
For a 2056 running 40IDF carbs and a mild cam, would I need the bluetooth model?
87m491 |
Oct 24 2023, 07:08 AM
Member Group: Members Posts: 275 Joined: 29-July 12 From: Portland, the original! Member No.: 14,731 Region Association: North East States |
Jeff everything I read from you regarding 123has been skeptical. Are you now all in? I think it needs a new 2 piece watertight quick disconnect connection for mating to the harness, a flexible protective wire covering over the exposed wires, and something to watertight the wiring penetration at the dizzy body. A "non problem" searching for a solution? Does anyone drive their 914s in the rain? |
JeffBowlsby |
Oct 24 2023, 10:02 AM
The problems are real.
The open engine bay allows water in. Even if the car is never driven in rain or washed, engine heat degrades unprotected wiring as is provided by the 123 dizzy with the trigger points wiring. The proposed watertight quick disconnect to the FI harness (even if a watertight connection is not needed), minimizes corrosion of the terminals and dirt/grease contamination of the electrical connection. The proposed wiring protection also provides stress relief protection of the wiring as it enters the dizzy, from engine vibration |
slapshot |
Oct 24 2023, 10:28 AM
Member Group: Members Posts: 58 Joined: 11-June 23 From: Utah Member No.: 27,409 Region Association: Rocky Mountains |
I have been planning on buying one. I've been waiting to see what deals they had on black Friday. Looks like they have done 10% off in the past.
Attached thumbnail(s) |
cashiersjm |
Oct 24 2023, 04:22 PM
Member Group: Members Posts: 40 Joined: 6-December 09 From: Cashiers, North Carolina Member No.: 11,100 Region Association: South East States |
I'm in for the wireless programmable 123\TUNE+4-R-V-P for a carbed engine. I got a text from Ed today confirming this is the one for carbs.
iankarr |
Oct 24 2023, 09:23 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,480 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
More than a group buy...a MUST buy. Night and day diffference. Plus with the bluetooth model you can set a passcode for the car and it won't start without the code. Way easier security than pulling the coil wire (IMG:style_emoticons/default/wink.gif)
Lo-Fi Version | Time is now: 1st June 2024 - 07:08 PM |
