DC_neun_vierzehn
Oct 20 2023, 10:28 AM
I just talked to Ed at 123 Ignition USA and he's agreed to set up another group buy for 914 World members. He will give us a code that will provide an instant 5% off and then if we 10 people use that code in 30 days everyone will get another 5% refunded (for a total discount of 10%).
I don't want to get that code yet because we'll be on the 30 day clock once he provides it. I'm thinking we could get the code on November 1st.
Who would be interested besides me and
@FlacaProductions ?
FlacaProductions
Oct 20 2023, 11:08 AM
Thanks for being the honcho on this - very nice!
JeffBowlsby
Oct 20 2023, 11:18 AM
DC_neun_vierzehn
Oct 20 2023, 01:20 PM
For those that are unfamiliar with 123 there are plenty of threads about the benefits. Here's a recent thread:
http://www.914world.com/bbs2/index.php?showtopic=364592
914_teener
Oct 20 2023, 02:44 PM
I think I did the original group buy on these.
Back then, they only had the switched version for D-jet and blue tooth for carbs.
For stock D-jet the switched version ran just fine and for those who don't know "switched" means the curve configurations are (were) hard mapped in the dizzy.
So I noticed that there is a considerable price difference between the mappable dizzy and the hard mapped dizzy (switched)..bout $200.
Still, I'd say hands down, the best improvement for drivability I ever did on that car.
Stratfink
Oct 21 2023, 01:44 AM
I’ve been considering this. The group buy could be the incentive to pull the trigger.
DC_neun_vierzehn
Oct 21 2023, 08:05 AM
QUOTE(914_teener @ Oct 20 2023, 02:44 PM)
Huge endorsement there
"the best improvement for drivability I ever did on that car." @BeatNavy said the same thing - bluetooth option was not available for D-jet when he got his 123, which makes makes setup tricky. Seems like the bluetooth option is a no brainer now.
The 123 w/ bluetooth is not cheap ($500-ish), but worth it when you weigh in all of the potential troubleshooting headaches and expenses you'll save yourself from in the future. Just new trigger points (or rebuilt trigger points) alone are nearly 50% of the cost of a 123 w/ bluetooth.
saigon71
Oct 21 2023, 09:02 AM
Count me in for this group buy. Thanks for setting it up.
aharder
Oct 21 2023, 11:54 AM
I've been thinking of one for a long time so you can count me in also.
I just need to determine which one, I think it's the BT Tune + Porsche 4-R-V since I'm running Weber 40's and will have the same on my 2056 in progress.
Front yard mechanic
Oct 21 2023, 02:58 PM
QUOTE(JeffBowlsby @ Oct 20 2023, 09:18 AM)
Jeff everything I read from you regarding 123has been skeptical. Are you now all in?
Porschef
Oct 21 2023, 03:40 PM
If the thought even entered your mind, then just do it. Yes, there are no less expensive alternatives to points and condensers but nothing has made my car run better.
Yeah, the half G is a hit to some, myself included, but the old expression “Buy once, cry once” really applies here.
And there’ll be no crying after it’s dialed in.
JeffBowlsby
Oct 21 2023, 09:05 PM
QUOTE(Front yard mechanic @ Oct 21 2023, 01:58 PM)
Not skeptical, I think the 123 is technically a good solution. The only concerns I brought up before were related to the djet trigger points connection to the harness. It’s not resolved at all and is a long term problem. I think it needs a new 2 piece watertight quick disconnect connection for mating to the harness, a flexible protective wire covering over the exposed wires, and something to watertight the wiring penetration at the dizzy body. It would be great if 123 would provide this to make their dizzy plug ‘n play. If they would send me a complementary djet dizzy for my 74 914 2.0L djet I could develop a solution.
DC_neun_vierzehn
Oct 23 2023, 12:36 PM
Looks like we have 5 in so far for the group buy:
1.
@FlacaProductions 2. @DC_neun_vierzehn
3.
@Stratfink 4.
@saigon71 5.
@aharder Just need 5 more.
jim-c
Oct 23 2023, 02:52 PM
I had one of these installed on my 2.0 . It worked great . Easy to install, quality piece. I had the Bluetooth model and the ability to adjust timing at various rpm was very helpful .
flipb
Oct 24 2023, 06:43 AM
For a 2056 running 40IDF carbs and a mild cam, would I need the bluetooth model?
87m491
Oct 24 2023, 07:08 AM
QUOTE(JeffBowlsby @ Oct 21 2023, 07:05 PM)
A "non problem" searching for a solution? Does anyone drive their 914s in the rain?
JeffBowlsby
Oct 24 2023, 10:02 AM
The problems are real.
The open engine bay allows water in.
Even if the car is never driven in rain or washed, engine heat degrades unprotected wiring as is provided by the 123 dizzy with the trigger points wiring. The proposed watertight quick disconnect to the FI harness (even if a watertight connection is not needed), minimizes corrosion of the terminals and dirt/grease contamination of the electrical connection.
The proposed wiring protection also provides stress relief protection of the wiring as it enters the dizzy, from engine vibration
slapshot
Oct 24 2023, 10:28 AM
I have been planning on buying one. I've been waiting to see what deals they had on black Friday. Looks like they have done 10% off in the past.
cashiersjm
Oct 24 2023, 04:22 PM
I'm in for the wireless programmable 123\TUNE+4-R-V-P for a carbed engine. I got a text from Ed today confirming this is the one for carbs.
iankarr
Oct 24 2023, 09:23 PM
More than a group buy...a MUST buy. Night and day diffference. Plus with the bluetooth model you can set a passcode for the car and it won't start without the code. Way easier security than pulling the coil wire
87m491
Oct 25 2023, 06:07 AM
email sent
QUOTE(DC_neun_vierzehn @ Oct 23 2023, 10:36 AM)
1.
3.
@Stratfink 4.
@saigon71 5.
flipb
Oct 25 2023, 07:38 AM
OK, count me in.
DC_neun_vierzehn
Oct 25 2023, 07:42 AM
QUOTE(slapshot @ Oct 24 2023, 10:28 AM)
I'll just ask Ed straight up if they're offering a discount on Black Friday.
And if they are, could he sweeten the group buy offer (e.g., 15% off?). Otherwise, we could all just do with the BF deal and I don't need to do all of this cat herding : )
I'll call Ed today. He seems like an honest and transparent dude.
FlacaProductions
Oct 25 2023, 09:22 AM
@DC_neun_vierzehn - I like this idea. For me, it's going to happen either way.
thanks for leading the way.
DC_neun_vierzehn
Oct 27 2023, 07:56 AM
Just talked to Ed. They are
not doing a black Friday deal this year. They did one years ago, but have since discontinued. Thus, this group buy is the last opportunity in 2023 to get a discount on a 123.
So far it looks like we have the following in on the GB:
1.
3.
@Stratfink 4.
@saigon71 5.
@aharder 6.
@flipb 7.
@87m491 8.
@cashiersjm 9.
@slapshot 10. ?
Please LMK if you're listed above and shouldn't be. Also please let me know if you should be listed above, but are not.
Craigers17
Oct 27 2023, 10:44 AM
QUOTE(DC_neun_vierzehn @ Oct 27 2023, 07:56 AM)
1.
3.
@Stratfink 4.
@saigon71 5.
@aharder 6.
@flipb 7.
@87m491 8.
@cashiersjm 9.
@slapshot 10. ?
Hate to see 1 spot holding up the deal....so count me in for a distributor and probably the coil too.
FlacaProductions
Oct 27 2023, 10:48 AM
Craigers17
Oct 27 2023, 11:07 AM
QUOTE(FlacaProductions @ Oct 27 2023, 10:48 AM)
You guys did all the hard work. I'm just jumping on the wagon. Besides, I'd really like one of these distributors.
fiacra
Oct 27 2023, 05:32 PM
I've been thinking about doing this for a long time now, so I'll be in as well. I'll probably get one for each of my two 914's. One for the 1.8 L-Jet and another for the 2.0 D-Jet. Both stock FI. Confirmed with Ed today that I had the correct choices in my cart. He sent me a discount code already, but I'll wait until I get the official word on this thread. Now I've just got to pull a few extra shifts to soften the blow on the savings account...
BuddyV
Oct 27 2023, 09:30 PM
I'm in too!!!
DC_neun_vierzehn
Oct 28 2023, 06:44 AM
Ok. So it looks like we have at least 10 now ...
1. FlacaProductions
2. DC_neun_vierzehn
3. Stratfink
4. saigon71
5. aharder
6. flipb
7. 87m491
8. cashiersjm
9. slapshot
10. Craigers17
11. fiacra
12. BuddyV
Here's the
discount code for us to use (even if you're not listed above you may use it):
914WORLDhttps://123ignitionusa.com/porsche/If you have any questions about which product(s) to buy for your particular 914 motor setup, just give
Ed at a call:
440-668-8164.
Remember, you will get 5% off immediately. Then after 10 buyers have used this code, we will receive an additional 5% refunded from our original payment.Cheers,
Kris
fiacra
Oct 28 2023, 09:42 AM
Order placed this morning for 2 distributors.
FlacaProductions
Oct 28 2023, 09:50 AM
Fantastic.
Gentlemen.....start your credit cards.
g911
Oct 29 2023, 11:48 AM
Excellent. Thank you!
JeffBowlsby
Oct 29 2023, 01:35 PM
What’s the last day to order with the discount code?
burton73
Oct 29 2023, 02:03 PM
Question is how fast can we get these. Marks 2270 car is ready for it in the next couple of weeks
Bob B
densible1
Oct 29 2023, 10:10 PM
I added 1 unit using group code.
Mark
fiacra
Oct 29 2023, 10:20 PM
QUOTE(burton73 @ Oct 29 2023, 01:03 PM)
Bob B
@burton73 I ordered 2 yesterday and got a message that they shipped today. I suppose the faster you order them the more likely they will ship right away. If they run out of stock you might have to wait for a restock. You can always ping Ed and ask. He responded to my question within a day.
87m491
Oct 30 2023, 08:15 AM
Ordered,
thx
QUOTE(FlacaProductions @ Oct 28 2023, 07:50 AM)
Fantastic.
DC_neun_vierzehn
Oct 30 2023, 08:18 AM
QUOTE(burton73 @ Oct 29 2023, 02:03 PM)
Bob B
Call Ed at 123 and ask him: 440-668-8164
DC_neun_vierzehn
QUOTE(JeffBowlsby @ Oct 29 2023, 01:35 PM)
I believe the code is active for 30 days.
flipb
Oct 30 2023, 08:26 AM
QUOTE(cashiersjm @ Oct 24 2023, 06:22 PM)
QUOTE(flipb @ Oct 25 2023, 09:38 AM)
OK, count me in.
I'm trusting this to be the correct answer for a Carbed 2056. Ordered (with coil) today.
slapshot
Oct 30 2023, 08:42 AM
Ordered.
Craigers17
Oct 30 2023, 08:53 AM
Ordered + coil. Talked briefly with Ed...seems like a great guy.....he said we were already at 7 or 8.
JeffBowlsby
Oct 30 2023, 09:51 AM
QUOTE(DC_neun_vierzehn @ Oct 30 2023, 07:18 AM)
A specific date please. 30 days from when? Nov 30?
fiacra
Oct 30 2023, 11:25 AM
QUOTE(JeffBowlsby @ Oct 30 2023, 08:51 AM)
@jeffbowlsby I pinged Ed today and he confirmed that the last day to use the code is November 30, 2023
JeffBowlsby
Oct 30 2023, 03:38 PM
Thx Broheen.
FlacaProductions
Oct 30 2023, 06:25 PM
Just ordered a bluetooth D-jet version and coil...really looking forward to it!
Robarabian
Oct 30 2023, 07:16 PM
I got in on another one as well. Thanks for arranging it. Ed is a great guy. I just sent him back mine to make sure it wasn't faulty and he replaced the whole circuit board just to be safe. Said likely nothing wrong with it. Threw in a new distributor cap for free as well. Good dude.
cashiersjm
Oct 31 2023, 09:47 AM
Just ordered 2 with coils
