WTB Mainely oil temperature gauge dipstick |
mm911 |
Nov 2 2023, 08:48 AM
Newbie Group: Members Posts: 9 Joined: 18-January 13 From: martin tennessee Member No.: 15,385 Region Association: None |
Want to buy Mainely oil temperature dipstick for 914-4. Thanks
87m491 |
Nov 2 2023, 02:48 PM
Member Group: Members Posts: 275 Joined: 29-July 12 From: Portland, the original! Member No.: 14,731 Region Association: North East States |
Want to buy Mainely oil temperature dipstick for 914-4. Thanks https://vwparts.aircooled.net/Oil-Temperatu...dipstick-t4.htm https://www.busdepot.com/gb227 |
GregAmy |
Nov 3 2023, 06:35 AM
Advanced Member Group: Members Posts: 2,311 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
^^^ that does not tell you what the oil temperature is, only that it has exceeded 225/235 degrees.
I dislike this idea for two reasons: - One, 225-235F is not fatal for oil temp; in fact, it may be normal, and - Two, it turns on the oil pressure light which requires immediate SHUT IT DOWN NOW!!! action. This could have significant safety consequences, depending on the situation at the time. Bad mojo, IMO. If you want to wire that to a separate indicator light, fine, I have no issue with that (and it would be easy to do). But it's just not cool (har de har) to dual-purpose a serious warning light for a situation that does not require immediate action. @Mikey914 was mulling reproducing these out-of-production Mainely dipsticks; I presume nothing has come of it? - GA |
Mikey914 |
Nov 3 2023, 10:58 AM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Did some research with Jim and yes we can do these. I just need to put this together.
-Mark |
87m491 |
Nov 6 2023, 08:28 AM
Ward..." "Don't you think you're being a bit hard on the Beaver?
OP was just looking to buy a part not mentioning how he planned on using or for what purpose? ^^^ that does not tell you what the oil temperature is, only that it has exceeded 225/235 degrees. I dislike this idea for two reasons: - One, 225-235F is not fatal for oil temp; in fact, it may be normal, and - Two, it turns on the oil pressure light which requires immediate SHUT IT DOWN NOW!!! action. This could have significant safety consequences, depending on the situation at the time. Bad mojo, IMO. If you want to wire that to a separate indicator light, fine, I have no issue with that (and it would be easy to do). But it's just not cool (har de har) to dual-purpose a serious warning light for a situation that does not require immediate action. @Mikey914 was mulling reproducing these out-of-production Mainely dipsticks; I presume nothing has come of it? - GA |
euro911 |
Nov 6 2023, 08:36 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Ward..." "Don't you think you're being a bit hard on the Beaver? OP was just looking to buy a part not mentioning how he planned on using or for what purpose? Actually, the OP did ... "Want to buy Mainely oil temperature dipstick for 914-4 (IMG:style_emoticons/default/rolleyes.gif) |
Lo-Fi Version | Time is now: 1st June 2024 - 06:29 PM |
