3.2 Temp sensor connector - help!, 3.2 Temp sensor connector - help! |
Biggles |
Feb 25 2024, 12:29 PM
Member Group: Members Posts: 191 Joined: 5-September 13 From: UK Member No.: 16,353 Region Association: England |
Hi all
I had to take the temp sensor electrical connector off my 3.2, and it snapped in half ! Any ideas how to repair this in situ without getting a whole new loom ? Can the wires be cut and a new plastic fitting be soucred and connected? Cheers Chris Attached thumbnail(s) |
Superhawk996 |
Feb 25 2024, 01:08 PM
914 Guru Group: Members Posts: 5,904 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Get a new connector (or used).
De-pin yours (correct de-pin tools can probably be had on Amazon) Insert your pins into the new connector - OR - The old JB weld solution as a short term fallback if done carefully. Use quick set or their specialized plastics formula. I would avoid cut & splice if at all possible. |
Biggles |
Feb 25 2024, 01:27 PM
Get a new connector (or used). De-pin yours (correct de-pin tools can probably be had on Amazon) Insert your pins into the new connector - OR - The old JB weld solution as a short term fallback if done carefully. Use quick set or their specialized plastics formula. I would avoid cut & splice if at all possible. Thanks for your reply. I didnt know a de-pin tool was a thing! I'll go down this route as it seems more robust than a plastic repair (always a tricky material to bond i've found). Next question...anyone out there got a spare temp. sensor connector they dont need? Cheers. |
Superhawk996 |
Feb 25 2024, 01:29 PM
The trick is knowing which de-pin tool to use for a particular connector.
If you buy a used donor - you can use that to figure out how to de-pin yours so you’re not learning on yours with limited access in the vehicle. Google is your friend - then trial and error. I’ve done it a lot and can usually come up with the right tool and process in 5-10 minutes for the 1st one. Subsequent pins only take seconds once you know how to release them. Other option is find a good automotive electric shop - they will have tools and knowledge to re-pin it pretty quickly. They might have a source for obtaining new connector housing too? Note: the $7 version of these tools are pretty cheesy (soft metal) they will get the job done once or twice but they eventually break / fatigue. The more expensive kits will have steel or titanium working surfaces. |
Biggles |
Feb 25 2024, 01:41 PM
The trick is knowing which de-pin tool to use for a particular connector. If you buy a used donor - you can use that to figure out how to de-pin yours so you’re not learning on yours with limited access in the vehicle. Google is your friend - then trial and error. I’ve done it a lot and can usually come up with the right tool and process in 5-10 minutes for the 1st one. Subsequent pins only take seconds once you know how to release them. Other option is find a good automotive electric shop - they will have tools and knowledge to re-pin it pretty quickly. They might have a source for obtaining new connector housing too? Note: the $7 version of these tools are pretty cheesy (soft metal) they will get the job done once or twice but they eventually break / fatigue. The more expensive kits will have steel or titanium working surfaces. Ok thanks. Lots of options ! On closer inspection it looks like the connector is molded onto the two pins? Maybe glue is my option? Attached thumbnail(s) |
Superhawk996 |
Feb 25 2024, 01:44 PM
What does back side look like?
Molded in pins are pretty rare but I have never dealt with that particular connector. That plastic looks like it is probably thermoplastic (like ABS) so it would likely bond / glue OK. The trick will be using only enough glue to bond but not getting it into the mating surfaces. |
Superhawk996 |
Feb 25 2024, 01:51 PM
Oh -
Is backside molded in too? Does this terminate at the temp sensor? What is the zip tie holding together? Man - I feel your pain now. The more I look at that end, it doesn’t seem to be serviceable unless that zip tie is holding on some sort of cover that allows access to back side of pins. Even then that is a lot of distance from back of connector to front of pin and doesn’t look like the usual type of pins I’m used to. Lots of post and words to not be of much help to you. (IMG:style_emoticons/default/headbang.gif) |
87m491 |
Feb 25 2024, 02:25 PM
Member Group: Members Posts: 276 Joined: 29-July 12 From: Portland, the original! Member No.: 14,731 Region Association: North East States |
Hi all I had to take the temp sensor electrical connector off my 3.2, and it snapped in half ! Any ideas how to repair this in situ without getting a whole new loom ? Can the wires be cut and a new plastic fitting be soucred and connected? Cheers Chris Just put the 2 halves together, but not in the bracket holder, and heat shrink the connector together with appropriate sized heat shrink. |
Biggles |
Feb 26 2024, 08:58 AM
Oh - Is backside molded in too? Does this terminate at the temp sensor? What is the zip tie holding together? Man - I feel your pain now. The more I look at that end, it doesn’t seem to be serviceable unless that zip tie is holding on some sort of cover that allows access to back side of pins. Even then that is a lot of distance from back of connector to front of pin and doesn’t look like the usual type of pins I’m used to. Lots of post and words to not be of much help to you. (IMG:style_emoticons/default/headbang.gif) Yes, the plug connector is moulded onto the metal terminals - crazy but guess Porsche weren't thinking too far ahead! Its heat soak which has done it. No worries, thanks for the ideas. I think @87m491 has the solution that'll work best for me. |
Biggles |
Feb 26 2024, 09:00 AM
mepstein |
Feb 26 2024, 09:02 AM
914-6 GT in waiting Group: Members Posts: 19,316 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Just by a new sensor.
Biggles |
Feb 26 2024, 12:24 PM
ClayPerrine |
Feb 26 2024, 12:30 PM
Life's been good to me so far..... Group: Admin Posts: 15,525 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Just by a new sensor. (IMG:style_emoticons/default/agree.gif) This is a critical item for your car. Without it, the engine won't run. Don't do a halfway job and try to fix this. Look at it this way, how much does it cost to have your car towed home? Make sure to include the time lost sitting on the side of the road waiting for the truck to show up, and your wife's good will too. That 100 Pounds might be a LOT cheaper when you actually factor in all the other items. |
mepstein |
Feb 26 2024, 12:38 PM
Just by a new sensor. (IMG:style_emoticons/default/agree.gif) This is a critical item for your car. Without it, the engine won't run. Don't do a halfway job and try to fix this. Look at it this way, how much does it cost to have your car towed home? Make sure to include the time lost sitting on the side of the road waiting for the truck to show up, and your wife's good will too. That 100 Pounds might be a LOT cheaper when you actually factor in all the other items. We see sensors as consumable items and always replace them during rebuilds for the reasons Clay stated. It’s not just the plastic connections that break. The wires and housing wear out, time out and beak down. |
Lo-Fi Version | Time is now: 11th June 2024 - 11:40 AM |
