911 Flywheel, Got a used motor... |
yeahmag |
Oct 31 2005, 04:13 PM
Advanced Member Group: Members Posts: 2,422 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
I managed to find a used core motor from a board member (Thanks again Randy) and it came with what looks to be a 911 Flywheel. What, if anything, do I need to know about this conversion?
The bolts were very difficult to get at (13mm) due to the proximity to the edge. Does this flywheel need a allen head bolt? Thanks. -Aaron |
Aaron Cox |
Oct 31 2005, 04:14 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
wha???
pictures? this a 4 or a 6? |
yeahmag |
Oct 31 2005, 04:31 PM
This is on a 2.0 /4. The flywheel appears to be the same size and shape as the /4 (for example, the PP fit my /4 flywheel), but the back edge is rounded (so it would be lighter). I can try and get a picture of it later tonight...
The preivious owner mentioned something about shimms, but wasn't too sure himself. -Aaron |
SLITS |
Oct 31 2005, 06:43 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
The only shims are the three (3), count them three (3) that go between the flywheel and the crankshaft to set the end play............
Cap'n Krusty |
Oct 31 2005, 07:43 PM
911 flywheels have SIX bolts on the crankshaft, 914/4s have FIVE bolts. They don't interchange, for reasons that should be obvious. If you are having a hard time getting a socket on the perimeter bolts, which hold the cover in place, it's likely the flywheel is junk becauise it's been cut too far. The Cap'n
TimT |
Oct 31 2005, 07:55 PM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
or Nine or even more.... what year is the engine? there were a few permutations in 911 flywheels over the years.. |
yeahmag |
Nov 2 2005, 06:10 PM
The engine is a '75. I gave up my practically new 914 flywheel!!! Doh!
I'll try and get a picture tonight. -Aaron |
yeahmag |
Nov 3 2005, 10:28 AM
Here's a picture of the flywheel...
Attached image(s) |
yeahmag |
Nov 3 2005, 10:29 AM
another...
Attached image(s) |
Mark Henry |
Nov 3 2005, 11:43 AM
It's a /4 that's been lightened
It needs a regrind and by the looks of the ground down fly bolts it most likely is to far cut to regrind. You need a better or new flywheel. |
yeahmag |
Nov 3 2005, 12:38 PM
Anybody have a good used flywheel?
-Aaron |
SLITS |
Nov 3 2005, 02:46 PM
Yeh....I should have a couple in Riverside....come to the VegasRacer Dinner at El Torito in Ontario this Saturday Night...I could carry one with me.
Lo-Fi Version | Time is now: 2nd June 2024 - 06:00 AM |
