Timing on a /6, Where's the mark? |
Allan |
Dec 18 2005, 10:48 AM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
Since I don't have a Haynes manual for a /6 I was wondering how you go about setting the timing while it is installed in a 914? Where are the timing marks and how do you get to them?
Tx... |
TimT |
Dec 18 2005, 10:50 AM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
you should see this looking down onto the engine/tranny
Attached image(s) |
J P Stein |
Dec 18 2005, 11:27 AM
If you have pre-marked your flywheel, Tim's pic is good.
If not, the timing marks are on your front pully....at TDC, 5 DEG BTDC, & 35 deg BTDC. You'll need mirrors & stuff. Or, cut a hole in yourfire wall. Or set the front pully at TDC and mark that on the flywheel(even with the case split),5deg & do the same,35deg & do the same. |
Lo-Fi Version | Time is now: 8th June 2024 - 12:32 PM |
