> Paint/bodywork question, Lou's update got me thinkin'
URY914
post Jan 16 2006, 07:58 PM
I'm about ready to prime and paint my car and the question is...
Do you think I REALLY need to prime it?
a. It is a race car so the paint only needs to look good from 15 feet. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
b. It is fiberglass. (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif)
c. Let me say it before someone else does: It will add weight. (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
Now will the finish coat stick w/o a primer? Or do I need a primer over f/g?
I plan on using a Du Pont Nason product called Astron synthetic enamal with a hardener. It's a inexpensive (cheap) paint brand.
Whata ya think???
Paul
Replies(1 - 14)
Aaron Cox
post Jan 16 2006, 08:00 PM
Professional Tinkerer
use IMRON (IMG:http://www.914world.com/bbs2/html/emoticons/tongue.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/smoke.gif)
URY914
post Jan 16 2006, 08:01 PM
QUOTE (Aaron Cox @ Jan 16 2006, 06:00 PM)
I'm not going to LeMans and showing it at Pebble Beach. (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif)
TimT
post Jan 16 2006, 08:06 PM
retired
What type of finish is on the glass now? is it gel coat? I started priming all the glass on my car, then tried just paint over the gel coat, and it works fine.
Im using a waterbased color coat, and on of the Dupont clears
jimkelly
post Jan 16 2006, 08:10 PM
Delaware USA
I think a gloss paint despite adding weight would give you a better drag coefficient to to less resistance of the air over the body surfaces ??
Why not do it black epoxy prime with a clear satin gloss for the rough but purposeful look?
Looking forward to seeig the finished product.
Jim
post Jan 16 2006, 08:15 PM
Resident German
QUOTE (jimkelly @ Jan 16 2006, 06:10 PM)
NO BLACK FINISH !!!
black paint absorbs more heat, more heat = more energy, more energy = more gravitational pull !!!
conclusion:
black paint will make your car heavier !!!
(IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) Andy
URY914
post Jan 16 2006, 08:18 PM
QUOTE (TimT @ Jan 16 2006, 06:06 PM)
Some areas have gel coat but I'll mostly be repainting over my old paint job.
jimkelly
post Jan 16 2006, 08:21 PM
Delaware USA
That explains why I could not keep up with a dodge viper the other day : )
Lou W
post Jan 16 2006, 08:42 PM
Region Association: Spain
URY914 Posted on Jan 16 2006, 07:18 PM
What about stripping the old paint, put a lite coat of primer for adhesion, and maybe 2-3 quarts of paint, I wouldn't think that the overall weight gain could be that much.
URY914
post Jan 16 2006, 08:47 PM
The weight of the primer is not really a big issue, just a joke. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) I was trying to save a step really. If I need light coats, I'll do it. I could spray on some light coats and wait a few hours and shoot the finish. Right?
Lou W
post Jan 16 2006, 09:04 PM
URY914 Posted on Jan 16 2006, 07:47 PM
The weight of the primer is not really a big issue, just a joke.  I was trying to save a step really. If I need light coats, I'll do it. I could spray on some light coats and wait a few hours and shoot the finish. Right?
(IMG:http://www.914world.com/bbs2/html/emoticons/owned.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) Yes, I would put a couple light coats then finish coats, it should be fine. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
geniusanthony
post Jan 16 2006, 09:20 PM
Its a brand new "Chrome-sicle"
[QUOTE] could spray on some light coats and wait a few hours and shoot the finish. Right?
I am questioning the wait a few hours for finish coats, you should only let the paint tack up between coats for better stick..less chance of contamination and defects in the finished product. Check with paint manufacturer...longer for cold climates also
r_towle
post Jan 16 2006, 09:30 PM
Custom Member
400 grit and shoot the paint.
It will stick fine.
clean clean clean...and de-grease.
We just used the cheapest paint off of ebay...40 bucks a gallon and it sticks fine, no primer over the old paint..
The only reason to strip /prime is if the old paint is not sticking now, or if you have cracks in the paint.
Go for it in one shot..it will be great.
Rich
URY914
post Jan 16 2006, 09:47 PM
QUOTE (r_towle @ Jan 16 2006, 07:30 PM)
That is the answer I was waiting for. (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
effutuo101
post Jan 16 2006, 11:20 PM
I just took mine to earl schieb, gave them a couple of hundred and called it good. I did do the prep work, but having them paint it in CA was easier then trying to clean up after the primer.... (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif)
- Lo-Fi Version Time is now: 1st May 2026 - 08:13 PM
