Pugbug |
Member ![]() ![]() Group: Members Posts: 449 Joined: 14-February 05 From: Victoria, BC Member No.: 3,604 ![]() |
I started building a center console so I can install a bass speaker in my car. When making the cardboard templates I found that it will run into the gas pedal. ...That can't be good.
Can anyone post a pic of the drivers side of a console, so I can see how this is dealt with? |
BarberDave |
Barberdave ![]() ![]() ![]() Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest ![]() |
(IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
On the drivers side the console side angles in away from the gas peddle,they hold it in that position with a small wood block at the fire wall end . Maybe someone has a pic. , my 914 is in storage or I'd send you one. Dave (IMG:http://www.914world.com/bbs2/html/emoticons/slap.gif) |
type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
i installed a factory console and then removed it because my right foot rubbed on the console. only size 9 shoes. if/since you're building a console, you could construct that side to allow for clearance for your lead (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) foot.
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,098 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
here ya go.
k Attached image(s) ![]() |
MoveQik |
What size wheels can I fit? ![]() ![]() ![]() ![]() Group: Members Posts: 4,645 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region ![]() ![]() |
...and you can see in the pic, his foot isn't even close to rubbing the console! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Pugbug |
Thanks for the photo.....Comfy looking sox yu got there guy.
RonD |
Ron Diederichsen ![]() ![]() Group: Members Posts: 97 Joined: 2-July 04 From: Boulder, CO Member No.: 2,286 Region Association: None ![]() |
Had the same foot rub problem so I took the little wood block out at the back and screwed the sides together. No more rubbing.
Grimstead |
Cheaky Monkey ![]() ![]() ![]() Group: Members Posts: 835 Joined: 20-March 05 From: Corona, Ca Member No.: 3,789 Region Association: Southern California ![]() |
(IMG:http://www.914world.com/bbs2/html/emoticons/chairfall.gif) |
Lo-Fi Version | Time is now: 16th June 2024 - 12:28 PM |
