| Terrance |
Mar 29 2006, 06:56 PM
Member ![]() ![]() Group: Members Posts: 125 Joined: 2-August 05 From: Milpitas, CA Member No.: 4,526 |
(IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif)
I need to "trim" the center tunnel a little so my pedals can fit better. How much of a structural factor is it to the car? see pics. Attached thumbnail(s)
| Terrance |
Mar 29 2006, 06:58 PM
Damn, that pic was a bit large.
| Terrance |
Mar 29 2006, 06:59 PM
pic of car.... Never to be finished
| Terrance |
Mar 29 2006, 07:00 PM
argh, forgot pic
| lapuwali |
Mar 29 2006, 07:01 PM
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
Looks to me like it would be a lot easier if you just remove that extra bit of pedal.
| Mueller |
Mar 29 2006, 07:03 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
now that you have a cage you should be fine...you can always cut and box-in the area....
nifty looking pedal setup, mind sharing the cost of it??? |
| Allan |
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) Just do some trimming on the pedal... From the pic it looks like it wont take too much. |
| Terrance |
Mar 29 2006, 07:07 PM
Boxing the pedal area is what I am going to do. I am making it easily maintainable.
There will be a box, somewhat. The pedals will drop in on one piece and bolted to the floor. Then, an aluminum cover with Dzus fasteners will cover it up and prevent debris from entering the cockpit. It will be fully sealed with rubber (hehehe), to prevent water from entering as well. Removing the extra stuff on the pedal won't happen. It's cast, and I need it for a foot support and to run the throttle cable. Tilton pedals, from ebay with master cylinders, $225! CNC brand gas pedal, $35 from Pitstopusa.com. I think the Tilton pedals are usually $250 w/o m/c's. Metal plate - $2 from metal shop. |
| Jeroen |
Mar 29 2006, 07:09 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
the tunnel is part of the structure, but since you have a cage, I'd think it wouldn't suffer much if you make some minor cuts in it
do you want to move it to the right more than you have in your pic? hard to judge from the pics, but maybe it's easier to modify the throttle pedal? lengthen it upward? nice car btw... got some more info/pics? |
| Andyrew |
Mar 29 2006, 07:21 PM
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,380 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California
You got yourself a cage, you'll be fine.
Im planning on having the same setup for my pedals... How much did it all cost you? Thanks Andrew |
| Mueller |
Mar 29 2006, 07:24 PM
scroll up a post or 2 (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
| byndbad914 |
Mar 29 2006, 07:32 PM
shoehorn and some butter - it fits ![]() ![]() ![]() Group: Members Posts: 1,547 Joined: 23-January 06 From: Broomfield, CO Member No.: 5,463 Region Association: None |
Terrance - have you moved your drivers seat over a bit to line up with the pedals better? Just wondering - I have a Tilton triple pedal setup in mine in just about the same area, and I moved my drivers seat over about 1-1/2" inboard and still felt I had to "reach over" a little with my left foot to push the clutch. With the tube car, I am going to move the pedals to the left a bit (where that other structural piece is) so I can line up with the clutch better.
I have a really heavy clutch in the car and lining straight up with the pedal would be a real advantage for me. Just wondering what you're thoughts/experience is with having the pedals mounted there. |
| Mueller |
Have you seen how skinny that young punk is???? (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) ...yea, I'm jealous (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) |
| neo914-6 |
Mar 29 2006, 07:33 PM
neo life ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,086 Joined: 16-January 03 From: Willow Glen (San Jose) Member No.: 159 |
Terrance, I thought you were a CSOB (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) What does this buy you, less pressure on the legs? Here's another Tilton in 914 Nice BTW... |
| bondo |
Mar 29 2006, 07:36 PM
Practicing my perpendicular parking ![]() ![]() ![]() ![]() Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
I cut the top of my tunnel out (to put stuff in there, weld clutch tube, kill rust, etc.) and without most of the tunnel the floor still seems plenty strong. (I'll be welding the top back on) I still wouldn't run a car without one, but taking a little chunk out should be fine.
| Terrance |
Mar 29 2006, 08:25 PM
byndbad914 - I will definately have to move the seat over more. Since it's a race car, I can do some drilling. Most porsches are offset for some reason. I was thinking of moving the pedals to the left, but it won't work for me, because the M/C's are so long, I have to cut into the firewall and mount it farther forward.
Neo - I saw those pics, thanks. I wonder how much of the firewall was cut to fit? I had to chop mine up to do make clearance for the M/C's. Overall, I did this so I can have nice solid pedals to use, and good M/C's. the gas pedal is dope. Soooo smooth, and not wobbly. I have to cut the tunnel, and mount the pedal a little more crooked to make some clearance for heel-toe action, and also make sure I dont' step on 2 pedals at the same time. |
| Terrance |
Mar 29 2006, 09:55 PM
I figured it out. Tilton makes shorter master cylinders, which will save me almost 2". Which means, I can move the pedals even farther forward, so I can tilt my seat more, and sit even lower in the car.
| Mugs914 |
Mar 30 2006, 10:28 AM
"Hey, yellow IS faster!" ![]() ![]() ![]() Group: Members Posts: 618 Joined: 22-July 05 From: Temple TEXAS Member No.: 4,452 Region Association: Southwest Region |
Thats what I did too, Terrance. I think the M/Cs are Tilton 75 series, or something like that. I built a box in the floor so I could move them farther forward. I managed to get the seat a bit lower too. I also moved the seat over so that it sits right up against the tunnel. Pretty straight shot at the pedals that way.... Here are a few pics: Pedal box from the inside... Attached image(s)
| Mugs914 |
Mar 30 2006, 10:30 AM
Here's a somewhat lame shot of the pedal box from the outside, but it might give the idea...
| Mugs914 |
Mar 30 2006, 10:31 AM
This gives an idea of where the seat is situated....
Lo-Fi Version | Time is now: 16th March 2026 - 09:48 PM |
