Gt valance with brake ducts fabrication, I've started |
iamchappy |
Apr 7 2006, 11:14 AM
It all happens so fast! Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest |
The iamchappy 914 gt turbo project is underway, I am working on the brake ducts and added some removable thick rubber canards, I am considering and may lower the front opening for the oil cooler cutout about an inch as I am using the stock bumper.
Also here are some pictures of my new Supertech 12 plug dizzy conversion. (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif) Attached image(s) |
iamchappy |
Apr 7 2006, 11:15 AM
pic
Attached image(s) |
iamchappy |
pic 2
Attached image(s) |
iamchappy |
Apr 7 2006, 11:16 AM
diz
Attached image(s) |
iamchappy |
Apr 7 2006, 11:17 AM
diz 2
Attached image(s) |
Aaron Cox |
Apr 7 2006, 03:37 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
Did AIR make that piece?
i have the same one and fit is NOWHERE near close..... |
echocanyons |
Apr 7 2006, 04:12 PM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
Great Ideal and it looks good too. What did you use for the brake scoops/ducts?
iamchappy |
Apr 7 2006, 06:25 PM
Scoops are for a Shelby Mustang there actually side scoops.
I am running the hose ducting up underneth the headlight bucket into that area under it, then out into the trunk then back out the wheel well to the rotors. The ducts are just tacked into place with a little Kitty Hair, I am even thinking about lowering the opening of the oil cooler cut out by an inch since I will be using the stock bumper. Now to remove it and finish it up. Oh, I purchased it from Rennespeed the quality is lacking the underside is pretty wavey but can easily be straightened out. (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) |
Andyrew |
Apr 7 2006, 07:36 PM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
Someone's running a bit too much camber on the street!! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Cool project, I'll be watching this one. |
iamchappy |
Apr 7 2006, 09:19 PM
The inside of the tires were gone in about 5000 miles, a realignment before the new tires go on. Good thing they were cheapo Yokohama ES100's, which are great tires for the money.
iamchappy |
Apr 21 2006, 07:34 PM
Ive done some more work on it and shown here a test fit. I lowered the oil cooler opening about an inch and have the sealed up the brake ducts. soon I will start to duct my way to the rotors and finish off the shaping the filler.
Attached image(s) |
TimT |
Apr 21 2006, 07:54 PM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
QUOTE Did AIR make that piece? Aaron if its as crappy as the one you have yes they made it LOL AIR is almost (IMG:style_emoticons/default/stromberg.gif) |
iamchappy |
Apr 22 2006, 05:14 PM
Qarl did you see this?
Qarl |
Apr 22 2006, 05:22 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
reddog |
Apr 22 2006, 10:11 PM
Member Group: Members Posts: 71 Joined: 19-December 05 From: Willits, California Member No.: 5,299 |
(IMG:style_emoticons/default/icon_bump.gif) Nice job, but when I do mine I'll run the ducts more to the center and use the "torsion bar bump" as the inner side of the ducts...what do you think? (IMG:style_emoticons/default/beerchug.gif)
iamchappy |
Apr 22 2006, 11:18 PM
I placed mine in line with the headlight buckets, not only do i feel that it keeps everything in balance but it allows me to duct up into the void area under the headlight bucket.
redshift |
Apr 23 2006, 03:43 AM
Bless the Hell out of you! Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 |
I have done NOTHING to my car!
You all suck equally, and have fallen... long... of the grace of Gawd! I am a a miserable piece of (IMG:style_emoticons/default/stromberg.gif) M |
iamchappy |
Apr 23 2006, 09:22 AM
I have done NOTHING to my car! You all suck equally, and have fallen... long... of the grace of Gawd! I am a a miserable piece of (IMG:style_emoticons/default/stromberg.gif) M But think of the all the money your saving |
Lo-Fi Version | Time is now: 15th June 2024 - 02:42 PM |
