914forme |
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None ![]() ![]() |
Today got done with my job, and got to work on a few items before they depart. My Truck is heading to Florida for 6 weeks with a trailer in tow. I decided it was time to upgrade my brake controller, I did some research and came up with this.Jordan Brake Controller.
Installed hope it works, will test with their trailer tomorrow. So here we go step one install the cable mount on the brake pedal, yep it uses a physical attachment to measure brake application. Big plus when pulling in the mountains. Attached image(s) ![]() |
914forme |
Next is the cable guide, thank you GM you gave me the perfect hole palcement predrilled.
914forme |
Next mount the controller - it has two screws, had to drill the dash (IMG:style_emoticons/default/mad.gif)
Tried to get it into one of the many pockets on the truck - could not because of cable routing. Attached image(s) ![]() |
914forme |
Route the cables and plug in the factory wiring harness, all done.
TimT |
retired ![]() ![]() ![]() ![]() Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 ![]() |
Ive never seen that controller.
I have a Draw-tite controller plugged into a pigtail that Ford was nice enough to provide. Works well with my close to 10000# trailer |
URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 121,098 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
I have the trailer towing package on my Dodge and the wiring harness is prewired for after market brake controllers. Sweet!
Plug it in and go (I mean stop) |
914forme |
Hey Paul, I figured you did not need a set of trailer brakes for your trailer. I mean what can it weigh, you have probably lightened it also. (IMG:style_emoticons/default/av-943.gif)
URY914 |
Hey Paul, I figured you did not need a set of trailer brakes for your trailer. I mean what can it weigh, you have probably lightened it also. (IMG:style_emoticons/default/av-943.gif) My trailer is aluminum. (IMG:style_emoticons/default/happy11.gif) (IMG:style_emoticons/default/w00t.gif) |
Lo-Fi Version | Time is now: 15th June 2024 - 11:42 AM |
