Name that throwout bearing ? Need help ID-ing it, V-8 guys > anyone using one that looks like this ? |
v82go |
Aug 31 2006, 04:38 PM
Resident Contrarian Group: Members Posts: 249 Joined: 9-December 04 From: Lakeland, Fl. Member No.: 3,250 |
Hi
Decided to do something about my slightly noisy throwout bearing. After prying for 2 hours trying to seperate the motor from the transaxle, I unbolted the release bearing arm and Viola, she seperated. Yes it is a puller type. Maybe a early 901 bearing ? It is a Sachs. Tomorrow I will try to look for a part #. It has been in there since 1993 . Can anyone ID it ? Thanks Bob PS Many thanks to Andy for getting us back online !!!!!!!!!!! Attached image(s) |
v82go |
Aug 31 2006, 04:41 PM
the jpg
Attached image(s) |
byndbad914 |
shoehorn and some butter - it fits Group: Members Posts: 1,547 Joined: 23-January 06 From: Broomfield, CO Member No.: 5,463 Region Association: None |
are you sure you have a 901 trans? I didn't think there were any pull-style 901s. 915s and 930s are pull style. if you hvae a 5spd, maybe you have a 915 (IMG:style_emoticons/default/confused24.gif) would be better if you did!
v82go |
Aug 31 2006, 04:46 PM
Yep it is a 901 type (4 speed, 1st removed)
can not get my picture to load ? Attached image(s) |
byndbad914 |
Aug 31 2006, 04:57 PM
would be intersting to see how they converted the clutch fork, or did they just swap the cable to the front? I would guess it is a Kennedy clutch - maybe they would know what is up with that. Like someone squeezed a 915 clutch assy into a 901
TimT |
Aug 31 2006, 05:07 PM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
That could be a t/o bearing from a pull type 901 (the 70-71 type 911 box)
One of the cool and frustrating tings about these cars is that you can mix and match lot of combinations of parts. Which can be a pain in the coconuts to figure out. for example my 914 has a 3.2 with a 915 flywheel and Sachs 915 RSR sports clutch. This is a pull clutch |
TimT |
Aug 31 2006, 05:11 PM
converting the clutch for is pretty easy. You have to relocate the fulcrum, and modify the case a bit for clearance.
Easy peasy this is one of my spare boxes Attached image(s) |
v82go |
Aug 31 2006, 05:23 PM
I emailed Kennedy pics, they informed me it was not one of theirs, Brett @ Kennedy sez it looks like a 915 PP with a early 901 (pull type) bearing. The PP is marked 225 mm. Hopefully I will see some #'s on the bearing tomorrow.
Thanks Bob |
Lo-Fi Version | Time is now: 9th June 2024 - 07:28 AM |
