Piston oil squirters...how do they get thier oil??, /4 and /6 motors ???? |
Mueller |
Oct 26 2003, 11:10 AM
I know the oil squirters are installed in the crank mains on the block, but how do they get thier oil?
Are the crank bearings modified with a small hole to feed oil to the squirters? |
Brad Roberts |
Oct 26 2003, 11:11 AM
A passage is drilled down into the main oil feed for the bearing (the bearings have nothing to do with this).
Dont even think about it on your 4 cyl. B |
Charles Deutsch |
Oct 26 2003, 12:09 PM
Unregistered |
Here's some info that might help you.
Attached thumbnail(s) |
Charles Deutsch |
Oct 26 2003, 12:10 PM
Unregistered |
Charles Deutsch |
Unregistered |
Charles Deutsch |
Oct 26 2003, 12:11 PM
Unregistered |
redshift |
Oct 26 2003, 12:13 PM
Welp, there you go.
I am thinking blue billet squirters. M |
Brad Roberts |
Do you think you could scan a 911 ENGINE and show him how the oil passage work ??
How many scanner have you gone thru ?? B |
Charles Deutsch |
Oct 26 2003, 12:16 PM
Unregistered |
QUOTE(Brad Roberts @ Oct 26 2003, 10:13 AM) Do you think you could scan a 911 ENGINE and show him how the oil passage work ?? How many scanner have you gone thru ?? B My "reference library" contains more general auto info. I have no 911 engine stuff. |
Brad Roberts |
Oct 26 2003, 12:31 PM
Doh !!.. I seriously wanted you to post a 911 engine to show him how the squirter passages worked.
B |
TimT |
Oct 26 2003, 02:53 PM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
OK heres a scan from BAs book.
If you are going to have your case modifed for squirters, get the 964 squiters, rather than the 911 ones. The 964 units spray more oil. Also whats the best way to scan from a book? grayscale? photo? Attached image(s) |
Brad Roberts |
Oct 27 2003, 12:21 AM
Thanks Tim. This is EXACTLY what I wanted to show.
GreyScale is perfect. If you scan in color the file will be too large. B |
Lo-Fi Version | Time is now: 2nd June 2024 - 09:53 PM |
