> Unveiling new Nickies, For those of the six cylinder persuasion
cnavarro
post Nov 23 2003, 10:29 AM
Cylinder Guru
Anyone doing a six conversion and want Nickies for a 2.4/2.7/2.8? I have the first sets ever made ready for sale. And just for these intro sets (I have one set of 2.4s and one set of 2.7/2.8s) i'm selling the six cylinder set at four cylinder pricing. These cylinders have oe style seal grooves and are of the likeness of the original cylinders, so they'll fit like a glove without any mods. Here's your chance to try the best. Just provide your own pistons and use late model 911 head studs (those compatible with aluminum cylinders) or ARP studs and you're set! Email me for pricing and pics :-)
Charles Navarro
LN Engineering
http://www.LNengineering.com
Aircooled Precision Performance
Replies(1 - 19)
Jake Raby
post Nov 23 2003, 11:37 AM
Engine Surgeon
Buy Them!
scotty
post Nov 23 2003, 11:57 AM
The Fun Never Stops
Ooooo, pretty! Karl has got to have them for his six (IMG:style_emoticons/default/wink.gif)
Art! I'm going to have to get another job...
Eric_Shea
post Nov 23 2003, 12:05 PM
PMB Performance
I'm pulling the 2.2T out of my 71 911 and I'd like to build a SS 2.5 out of it, meaning 89 or 90mm P&C's. I plan to have my rod ends rebushed to answer the low compression problem.
What do you have that would work in this situation? I want to use S-cams and have roughly 9.5:1 or 9.8:1... no dual plug mods for me. What pistons do you recommend?
Thanks!
J P Stein
post Nov 23 2003, 01:30 PM
Irrelevant old fart
Yes, very nice, but you're gonna have to do "something "
about your pricing.
I've seen new in the box Mahle RS spec *pistons & cylinders* priced $1500-1700 in the past few months.
Eric: I would advise against using your 71 case for 90mm cylinders. It's been done and you *may* get away with it,
but a 5r(good) or 7r (better) case is the hot ticket.
cnavarro
post Nov 23 2003, 02:34 PM
Cylinder Guru
I have 84s and 90s on the shelf ready to bolt in. Regarding pistons, I have never spec'd out a set of custom JEs for a 911, so I would most likely recommend using either OEs or JEs, both of which I think I can source from EBS or similar outfits.
Now that I have everyone's attention, I'd like some input on where I should actually source pistons from so in the future I can make sure i'm providing the best available to my customers.
I'm all for doing a group buy to clear our the remainder of my inventory and i'm sure we can drop the price if enough people count their pennies....
Charles Navarro
LN Engineering
Jake Raby
post Nov 23 2003, 02:47 PM
Engine Surgeon
I have seen what goes into these cylinders, and used more than any other soul on earth!
As for pricing, he is already making very little profit. these cylinders are not cast- They are billet, and they are absolutely PERFECT in every facet.
I used the second set of Nickies ever made and can tell you now that nothing touches them! The price could be twice as much as it is currently and they would still be worth it!
TimT
post Nov 23 2003, 02:48 PM
retired
I have JE pistons in both my porsches now. ABout 10 yrs ago I did a rebuild and succefully used Arias pistons
Mahle go without saying, however they dont make "custom" CRs etc.
You can buy direct from JE
Britain Smith
post Nov 23 2003, 03:37 PM
Nano Member
Do you have a picture of these cylinders? I would be very interested in seeing the sealing surface on the top.
-Britain
Brad Roberts
post Nov 23 2003, 03:41 PM
914 Freak!
Damn.. I have a tricked out 3.2 that needs P+C's and a 2.4 case tricked out needing P+C's.
I say JE. I also say Call EBS for the pistons (JE will ask 500 technical questions that the normal Joe cant answer when ordering pistons).
Charles,
Thanks for posting this. I have held your components in my hands.. very high quality.
B
Jake Raby
post Nov 23 2003, 03:50 PM
Engine Surgeon
I pretty much live by JE pistons for higher Performance engines. Mahle has been going WAY down hill in the past few years, especially their piston balancing! I haveseen 23 grams difference in ONE set out of the box. Its impossible to remove 23 grams from a piston and keep it safe!
Im always willing to work woth Charleson piston designs! Tell us the CR you want and the bottom end spaces and head CC and thats what you'll get!
Brad Roberts
post Nov 23 2003, 03:53 PM
914 Freak!
I think Mahle was bought (or at least the US distributor was bought) We are now seeing ads for Mahle Motorsports out of South Carolina/North Carolina.
B
J P Stein
post Nov 23 2003, 04:24 PM
Irrelevant old fart
You'll not get far with the 9eleben crowd by poor mouthing Malhe P/Cs. They have untold millions of miles of both racing and street use backing up their reputation for excellence....Nikasil & Ausil. Thay also offer 90mm pistons
in 9.5 & 10.5 :1 ...albeit, at horse choker prices. Naturally these came out after I bought 90mm Shasta pistons for my 2.7L.
I have held the RS piston & the Shastas (one in each hand).
The weight difference is dramatic. WAG, the Shasta weighs 2/3 of the Mahle. The Shastas are made from JE forgings.
As to the pricing:
I was just stating what the marketplace is. The T-1 thru
T-4 crowd has no alternatives (AFAIK). The same is not so for the 911 bunch.
Jake Raby
post Nov 23 2003, 04:36 PM
Engine Surgeon
I do ALOT of dynamic balance onf 911 engines (all years) and the Mahle pistons have just been getting worse and worse......The newest 911 engine I work on is a 2.7, I know little about the newer engines.
Just like everytghing else, Mahle has gone down hill also over the years.....thats just the facts!
Tom Perso
post Nov 23 2003, 05:22 PM
Crazy from the Cold...
I can attest for LN's products. I held the first (and second set) of Nikkis and I helped Shad build his motor that used the first ever set of Nikkis. That car has been all over this country and is still running strong. Anyone who was at the Yipsi MI show this past year heard Shads car revving off the rev limiter numerous times during the day. He beats on it HARD.
Heck, I know LN pretty well, they slept in my living room this year on the way to a show!!! LOL, it's an outstanding company that is run by some standup people.
Later
Tom
DuckRyder
post Nov 23 2003, 05:28 PM
Avatars Mode: OFF because of the recalcitrant few.
QUOTE(Jake Raby @ Nov 23 2003, 06:36 PM)
.........Mahle pistons have just been getting worse and worse......................Just like everytghing else, Mahle has gone down hill also over the years.....thats just the facts!..........................
Congrats Jake, you just talked yourself into balanceing the rotating assy in my new motor.................. (IMG:style_emoticons/default/idea.gif)
cnavarro
post Nov 23 2003, 06:51 PM
Cylinder Guru
I'll have some pics for upload tomorrow morning or afternoon on both the 84s and 90s, as soon as my wife has a chance to shoot the pics for me. I also want to fill in the remainder of the 911 product line, so give me your input guys. Let me know what other cylinders are desired, give me a sample to work off of, and i'll get rolling on it asap.
Charles Navarro
LN Engineering
cnavarro
post Nov 23 2003, 07:40 PM
Cylinder Guru
Ok ok. I got emails from some anxious folks, so I dragged my wife away from the TV to take some pictures for me to share with everyone. For reference, I threw in there a 97mm Mahle Nikasil cylinder just to show the difference between cast and billet. Also note a few new touches like all the surfaces that were milled have been gone over with a custom radius-ing cutter to give every surface a detailed, intricate, and finished look. Finally, notice there's no plating on these. I want to make sure that the proper piston to cylinder clearances are established, so i'm waiting till I know exactly what piston is going to be used before having them finished. The pics can be found at http://www.lnengineering.com/911/index.html. Enjoy!
Charles Navarro
LN Engineering
JmuRiz
post Nov 23 2003, 07:49 PM
WOW, I don't think I could put those in a motor, they look like art. The extra cooling vanes are awesome! I just need to save up for some of the 914 nickies on my car, (IMG:style_emoticons/default/burnout.gif)
Jake Raby
post Nov 23 2003, 08:34 PM
Engine Surgeon
They are - ART!
They are a true joy to install! But not fun to machine on!
- Lo-Fi Version Time is now: 16th April 2026 - 11:19 PM
