orthobiz |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,758 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest ![]() ![]() |
I'm looking at a 76 Laguna 2.0 (at the pic stage right now) and see plugs fore and aft of the door sill. Car appears fairly rust free and lived a pampered life in the dreaded East and Midwest. Do the plugs have to be a bad sign? Could the longs still be in good shape? Maybe the good news is the rustproofing worked and that's why the car has not broken in half!
Paterek rustproofed my old 76 in the 80s, hid any holes, used (I believe) an oil-based ?Bosch product that seemed to work well over the years, still hasn't rusted out to this day. From what I remember, he pulled back the sail vinyl for rustproofing as well. Other products were some kind of spray foam, no? Where else would 914's commonly have plugs? Thanks, Paul Attached thumbnail(s) ![]() |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
Those holes don't go into the long. (IMG:style_emoticons/default/wink.gif) My camera battery is dead, so you get crappy cell phone pics.
Attached image(s) ![]() |
Brando |
BUY MY SPARE KIDNEY!!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California ![]() |
If you're talking of the black cap that goes into that square opening... That's a 'beauty plug' to cover your jack point.
jd74914 |
Its alive ![]() ![]() ![]() ![]() Group: Members Posts: 4,852 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States ![]() |
Twystd1 |
You don't want to know... really..... ![]() ![]() ![]() ![]() Group: Members Posts: 2,515 Joined: 12-September 04 From: Newport Beach, California Member No.: 2,743 ![]() |
Look for a Ziebart tag.
Back in the day. Several dealerships in SoCal used to sell an aftermarket rust proofing installation that was used primarily to get the dealership extra bucks for a product that was of little usefulness. (IMHO) The dealerships would drill holes in the car and put in a sprayed material call Ziebart rustproofing. Then install vinyl/rubber plugs in the drilled holes. I have seen several 914s and a butt load of Fiats with this treatment. I believe Ziebart is still in existence today. Try Google for more info. NOTE: It didn't work very well on SOME of the cars that I have seen. Cheers, Clayton |
orthobiz |
Just so there's no confusion, I'm talking about the black round plugs in front and behind the plastic door sill protector. Could they be for anything but rustproofing? Prior history of the car unknown. Initial pictures don't show plugs anywhere else.
Where else would Ziebart plugs show up? Thanks, Paul |
Grelber |
Insert favorite Don Rickles joke here. ![]() ![]() ![]() Group: Members Posts: 690 Joined: 30-May 06 From: McKinney, Texas Member No.: 6,107 Region Association: Southwest Region ![]() |
My car has the Ziebart plugs. The plugs are yellow, about 5/8" in diameter, and have a "Z" in the middle with "Ziebart" around the outside of the "Z". The plugs are in the lower rear of the doors, the door frame (front and rear) and also in the rear inner fender wells.
balljoint |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,001 Joined: 6-April 04 Member No.: 1,897 Region Association: None ![]() |
Those are "speed holes". They make the car go faster. (IMG:style_emoticons/default/smile.gif)
Grelber |
Yes, but NASCAR impounded my car and suspended my crew chief for them. (IMG:style_emoticons/default/biggrin.gif)
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,193 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
Mine was rustproofed also. Growing up in the Pittsburgh area, snow, salt, and non-galvanized metal took its toll on cars. Rustproofing was the only way to protect cars. Having the car rustproofed is a good thing with these cars. My 914 doesn't need it now since I drive only in dry weather.
Spoke Attached image(s) ![]() |
aircooledboy |
Sweet Pea's 1st ride in daddy's "vroom -vroom" ![]() ![]() ![]() Group: Members Posts: 1,672 Joined: 4-February 04 From: Rockford, IL Member No.: 1,629 Region Association: Upper MidWest ![]() |
The "rustiest" of my three parts cars had Ziebart rustproofing. (IMG:style_emoticons/default/huh.gif) The plugs are literally everywhere. These are black in color, and about 1/2" in diameter. The car has plugs into every possible cavity, for instance, there are probably 4 in each door, 4-5 in the ribs of each trunk lid. I have never been under the car, so I don't know if there are any into the longs.
The "rust proofing" is a waxy tar-like crud, insanely heavy, and in now exposed places you can see where it has cracked badly, trapped water, and obviously caused substantial rust on those panels. The only way I have found to remove it from a part is with a wire wheel. (IMG:style_emoticons/default/barf.gif) I would say conservatively, it added 10 to 15 lbs. to each door and trunk lid, and who knows how much to the body. (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 16th July 2025 - 04:25 PM |
