Delortos or Webers? |
computers4kids |
Aug 9 2007, 09:26 AM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
My ugly duckling project that I picked-up has some Weber 34s with all new linkage. I haven't had carbs for 25 years so bear with me.
I want to be able drive the car around as I work on it. Not to sure what I'm going to endup with for a powerplant so I don't want to invest too much here. Currently, the car starts and will idle fine but when you press on the gas it just goes "blah" and dies. To keep it running you have to pump the gas pedal to keep the rpms up. It makes me think vaccum leak---??. The 1.8 motor has a FI stock distributor. Couple of questions: OK...I realize from lurking on the board, an 009, 050, or mallory is a better performance distributor for carbs, but will the stock FI distributor work OK for now? Are the 34s worth rebuliding to get this car running OK? If I replace these carbs, it sounds like Weber 40s are what I would want or Dellortos (what size?) What is a good price for either of the carbs? Finally, since I have webers now, will the manifolds and linkage work on say some Weber or Dellorto 40s? Be Nice... Attached image(s) |
rhodyguy |
Aug 9 2007, 09:32 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,098 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
pretty sure the carb to intake stud pattern is dif for the ifds vs icts. if you're going to idfs, snag the set of cb talls in the classifieds. you can make them work with the 4 stud 1.8 heads.
k |
Twystd1 |
Aug 9 2007, 07:27 PM
You don't want to know... really..... Group: Members Posts: 2,514 Joined: 12-September 04 From: Newport Beach, California Member No.: 2,743 |
I love those little carbs on a stock engine.
Killer fuel mileage.... And pretty good performance. AND running an 009 is dizzy is not a good choice. An 050 works if it's recurved for your engine. (easy on a dizzy machine) Cheers, Clayton |
Lo-Fi Version | Time is now: 15th June 2024 - 06:02 PM |
