Turbo Tie Rod Install, Yet another front end story... |
Eric_Shea |
Dec 23 2003, 03:20 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Thanks to Karl and company, I got enough gumption to go out and try to remove the rack one more time. The universal under the dash was totally disassembled but still binding. Once that was behind me the rack hit the floor.
Time for the Turbo Tie Rods and a sprucing up. Here's some photos of the day: I started by pulling the spring retainers off. Attached image(s) |
Eric_Shea |
Dec 23 2003, 03:22 PM
The next setp was to remove the old tie rods from the rack. This is easily accomplished by turning the old rod up at a 90 deg. angle and using it as a lever to "crank" it off.
Attached image(s) |
Eric_Shea |
Dec 23 2003, 03:23 PM
I sealed off the ends and the steering gear input and took the assembly to my glass bead cabinet for some cleaning... end result.
Attached image(s) |
Eric_Shea |
Dec 23 2003, 03:27 PM
Then it was time to install the turbo tie rods. I actually had the proper sized wrench in a thin format so I was lucky here... best method is:
1. Take the ball joint end off. 2. Install the spacer on the tie rod and tighten to the rack. 3. Slip the rubber boot over the assembly. Make sure the small end fits in the groove on the rubber grommet that is on the rod. 4. Reinstall the ball joint end. Attached image(s) |
Eric_Shea |
Dec 23 2003, 03:33 PM
I also relubed the rack using caution when removing the cover so as to keep the gasket in decent order. I reassembled with a gasket compound.
I thought I'd throw in a "style shot" of the entire front suspension. It's all 911 based using the following components: 911 A-Arms 19mm Torsion bars 18mm factory sway bar from a 76 Turbo (one year only) Koni Struts and inserts with the spindles raised 18mm S-Calipers Vented/Drilled Brembos and of course Turbo Tie Rods. I'm working on finishing the wheel wells over the holidays so I can bolt it all back on! (IMG:style_emoticons/default/smash.gif) Onward... E. Attached image(s) |
Eric Taylor |
Dec 23 2003, 04:49 PM
Senior Member Group: Members Posts: 909 Joined: 1-June 03 From: Newport, OR/Eugene Oregon- UO Member No.: 770 |
very nice, what car is it going into?
Eric |
Gint |
Dec 23 2003, 05:49 PM
Mike Ginter Group: Admin Posts: 16,082 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
That looks really nice Eric. Great work!
seanery |
Dec 23 2003, 06:37 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
very nice stuff eric.
echocanyons |
Dec 23 2003, 07:15 PM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
Purdy work!
Nice job Eric |
Van914 |
Dec 23 2003, 07:18 PM
Van914 Group: Members Posts: 698 Joined: 5-January 03 From: Cincinnati, Ohio Member No.: 90 Region Association: Upper MidWest |
Eric,
When can you get to mine? Great job! (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/aktion035.gif) Van914 |
Eric_Shea |
Dec 23 2003, 07:33 PM
QUOTE very nice, what car is it going into? Thanks Eric, I guess I should explain that... not too many people know what I'm working on. It's going on a 74 that I'm doing a GT conversion on. My goal is to make it look as much like a factory GT as possible. I'm even digging into the nostalgic parts bin. I'm using period kind of stuff, hence the S-calipers and factory sway bar. I'm building a 3.0 SC motor for my 911 RS clone with S-cams, JE's, MFI bla, bla, bla. The 2.2 is coming out and I'm going to throw some 90mm nikasils on there, S-cams, rebush the rods (to bump the compression back up) and have a 2.5 short stroker for the GT. Hope the rods don't fall off! (little off topic humor for Rich) (IMG:style_emoticons/default/laugh.gif) My 914-6 is the canary yellow one in the avatar. That's off to the body shop for a complete paint job. It is all original and will stay that way. "Stitch" redid the door panels and fixed the peeling dash but the rest of the interior was in great original shape. Those are my three projects... |
Eric_Shea |
Dec 23 2003, 07:36 PM
QUOTE When can you get to mine? Send it on Van... I even have an extra set of Turbo Tie Rods. That plus $50 an hour is pretty cheap (IMG:style_emoticons/default/lol3.gif) |
Eric_Shea |
Dec 23 2003, 07:38 PM
Thanks Gint and all...
Mike, if you look real close you'll see those brand spank'n new ball joints on there! P210 is on it's way back home. Thanks mucho for the tool loan!!!!! (IMG:style_emoticons/default/beerchug.gif) |
Eric Taylor |
Dec 23 2003, 09:10 PM
Man Eric you have way to many cool project's!
Eric |
Eric_Shea |
Dec 23 2003, 09:38 PM
More like "way too many projects"... it would be nice to drive one instead of working on it. Some day. (IMG:style_emoticons/default/blink.gif)
Thanks... E. |
Gint |
Dec 23 2003, 11:10 PM
QUOTE Mike, if you look real close you'll see those brand spank'n new ball joints on there! P210 is on it's way back home. Thanks mucho for the tool loan!!!!! No problemo! |
Dunk |
Dec 24 2003, 12:37 AM
Newbie Group: Members Posts: 13 Joined: 23-December 03 From: NE of Nowhere...? Member No.: 1,462 |
Eric - that is sweet...!!! (IMG:style_emoticons/default/beerchug.gif)
Not to push you to the "next stage" - but what are you doing on the rear???? |
Brad Roberts |
Dec 24 2003, 03:46 AM
Eric,
Thanks for the pics. The club people really respond to the posts with pics. You would be amazed at the number of people that call me for parts and refer to a thread with detailed pics in it to point out what they are looking for. (IMG:style_emoticons/default/clap56.gif) Good job. It looks great. B |
Eric_Shea |
Dec 24 2003, 08:48 AM
QUOTE Thanks for the pics. The club people really respond to the posts with pics. No problemo... it's my way of pushing myself to completion. I like to post them up here to help people like me who come here for knowledge on the stuff. Although a Turbo Tie Rod install has been tackled many times, there might be one more person out there wanting to tackle the task and wondering what might be involved. Glad to help. QUOTE Not to push you to the "next stage" - but what are you doing on the rear???? Dunk? Is that you?? No pushing required... BTDT Check out the link! (IMG:style_emoticons/default/smile.gif) Click Here for the Rear Suspension |
Eric_Shea |
Dec 24 2003, 09:19 AM
QUOTE You would be amazed at the number of people that call me for parts and refer to a thread with detailed pics in it to point out what they are looking for. You mean like this? (IMG:style_emoticons/default/lol3.gif) Attached image(s) |
Lo-Fi Version | Time is now: 1st June 2024 - 06:58 AM |
