Coilover Conversion (Eiback/Ground Control), Shock is longer than spring? |
fiid |
Dec 26 2003, 03:09 PM
Turbo Megasquirted Subaru Member Group: Members Posts: 2,827 Joined: 7-April 03 From: San Francisco, CA Member No.: 530 Region Association: Northern California |
Hey,
So with the ride height set at an acceptable level, the spings are at rest and the shock is at nowhere near full extension. This mean that if I get air, the spring will be free to float around between the perch and the top cap. Is this okay? Normal? If thw spring supposed to be wired to the top?? There are a couple of holes in the the spring cap that look like they might be for wiring. Thanks in advance, Fiid. |
TimT |
Dec 26 2003, 03:26 PM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
QUOTE If the spring supposed to be wired to the top?? Yeap, you can wire it to the hat, or get helper springs which will keep the spring in position at full droop. its easier to wire the springs to the hats |
fiid |
Dec 26 2003, 03:29 PM
What would be a recommended material for somone who doesn't have any racing wire at the present time??
Cable tie? Coat hanger? Fiid. |
machina |
Dec 26 2003, 03:39 PM
Advanced Member Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
a couple cable ties should work, you won't have to think about it again.
worked for me. dr Attached image(s) |
fiid |
Dec 26 2003, 03:44 PM
ChrisReale |
Dec 26 2003, 09:36 PM
Sleazy Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 |
Fiid, I used cable ties also. What weight did you get?
DNHunt |
Dec 27 2003, 08:21 AM
914 Wizard? No way. I got too much to learn. Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
Glad I saw this thread. I forgot to tie the springs down.
Dave |
Eric_Shea |
Dec 27 2003, 10:36 AM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Let's see... forgot that I drained the tranny. Forgot to tie down the springs.
"Hey Honey... Where'd I put that 914?" "It's still in the garage Dear..." "Ohh... yeah... Thanks!" (IMG:style_emoticons/default/lol3.gif) |
Lo-Fi Version | Time is now: 4th June 2024 - 06:05 PM |
