Oil Temp Reading, Seems High ? |
jim_hoyland |
Nov 23 2007, 09:45 PM
Get that VIN ? Group: Members Posts: 9,318 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Today I installed a new 150 C VDO sender and a new wire to the 911 type Oil Temp/Pressure gauge ( Max 300 temp ). The temp along the coast wast 65 or 70 degrees and the engine oil temp was reading 200 - 220.
The oil dipstick thermometer is reading about 20 degrees lower. This seemed more realistic--180 -200 degrees Was wondering if anyone else had this happen and what you did. |
Twystd1 |
Nov 23 2007, 10:46 PM
You don't want to know... really..... Group: Members Posts: 2,514 Joined: 12-September 04 From: Newport Beach, California Member No.: 2,743 |
Since you live near the beach.... (I know where you live)
I HOPE the oil temp DOES get above 220 F. Else you will never cook the water out of your oil. The humididty where you live is high. So as the engine cools down to ambient. The engine pulls moisture to it. And inside the crank case via the breather. The engine HAS to get to 220 F plus to vaporize the water and vent it to atmosphere. Ya might want to check your dip stick temp gauge on the stove in a pot with some water. And see how accurate it is/ Hopefully you have a good thermometer in the house you can measure it by. Udder than that.. I don't know shit... But you knew that already.... Hey Jim....See ya at Joe's on the first and the seventh...!!!!!!! Clayton |
Aaron Cox |
Nov 23 2007, 11:20 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
taco plate sender?
type47 |
Nov 24 2007, 06:55 AM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
mismatch between sending unit and gauge?
jim_hoyland |
Nov 24 2007, 07:51 AM
There are two differences between the old and new sender wire: I used one gauge thicker wire and the wire does not have a second covering from the fire wall to the sender.
I put a pot in line with the gauge to see how many ohms makes up 20 degrees, it's like less than 100 maybe 10 or 20 ( my meter is not that sensitive) I'm thinking the wire is picking up some extra heat and reducing resistance. Thanks for the tip Clayton; you are right. I try to take the car out for a hard drive a least onec a week. Will see you all Dec 1--weather permitting. And, did the boilng water test on both sender to gauge and engine dip stick--both read 210 + = in boing water A 150 C sender maxes at 302 F--I believe the match is correct. Unless-----some 150 C senders have different OHM ranges. Is this possible ? Jim |
Lo-Fi Version | Time is now: 7th June 2024 - 06:04 PM |
