Stainless Steel cooling tin screws, Does anyone make them? |
chris914 |
Nov 24 2007, 10:56 PM
Member Group: Members Posts: 489 Joined: 24-July 04 From: San Diego, CA Member No.: 2,393 Region Association: Southern California |
If so were can you buy them?
Does anyone have a good source to buy fasnteners in general? |
McMark |
Nov 24 2007, 11:16 PM
McMaster.com
Part #91800A420 $8.23 for 50 of them. I order for McMaster almost weekly. They have everything. |
Gint |
Nov 24 2007, 11:42 PM
Mike Ginter Group: Admin Posts: 16,082 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Positive on that part number? Slotted? Cap screw would be better IMO. I can have Sharon order some for me.
Edit: Found it in the catalog. Obviously slotted. 91800A420 Metric Cheese Head Slotted Machine Screw 18-8 SS, M6 Size, 10 mm Length, 1 mm Pitch In stock at $8.23 per Pack This product is sold in Packs of 50 |
SGB |
Nov 25 2007, 12:19 AM
just visiting Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
Could we generate a list with some other favored commonly used parts? Like the parts number above and the cap screw version and I guess the 10 mm version too. and maybe those odd stubby pan head screws on the headlight fairings and headlight drive mechanism covers, other larger hardware pieces like trans and engine mounting nuts and washers, ec. Whats a typical Mcmark order?
chris914 |
Nov 25 2007, 12:24 AM
Is there a version that has the washer apart of the screw?
eg914 |
Nov 25 2007, 01:34 PM
Member Group: Members Posts: 319 Joined: 17-June 04 From: Elk Grove, CA Member No.: 2,223 Region Association: None |
You can also get packages of screws for the cooling tin at the local Bug shops, they use the same screws.
VaccaRabite |
Nov 25 2007, 02:11 PM
En Garde! Group: Admin Posts: 13,456 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
AA Also has the ones with the washer.
euro911 |
Nov 25 2007, 02:25 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
I bought some phillips head ones at Serrano's before he went under. Sorry I didn't get 100's more of them (IMG:style_emoticons/default/dry.gif)
I'm gonna need a bunch coming up, I'll see if J-Bugs carries them (IMG:style_emoticons/default/idea.gif) |
McMark |
Nov 25 2007, 03:15 PM
QUOTE You can also get packages of screws for the cooling tin at the local Bug shops, they use the same screws. Yes you can, and they have the captive washers, but aren't stainless steel, AFAIK. QUOTE Whats a typical Mcmark order? My typical orders aren't usually 914 universal parts. Mostly I'm ordering specific parts for custom projects. Such as a specific size of stainless steel rod to turn on a lathe to make a certain part for a subassembly, specific rubber mounts for an A/C condenser install, or full extension ball bearing drawer sliders for a custom hide-away Playstation installtion. Most of my custom projects start with a trip to the McMaster web site to research what's available that will fill my needs. Just typing this reminded me that I need to order some lexan 'billets' for a custom reverse light lens project. |
TheCabinetmaker |
Nov 25 2007, 03:19 PM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Check your local yellow pages for "fasteners". You'd be surprised what you can find locally.
euro911 |
Nov 25 2007, 03:49 PM
Absolutely. There's a little mom & pop hardware store ('Lovelady Hardware') a few blocks away that has a nicely-stocked 'Bolt Room' ...
Bought all the s/s hardware there when I built support racks for my solar panels. Home Depot & Lowe's didn't have the quantities I needed and they were way less expensive than the local 'Marine' Hardware stores. Attached image(s) |
TheCabinetmaker |
Nov 25 2007, 04:00 PM
Nice job Mark
McMark |
Nov 25 2007, 04:14 PM
Added to the Parts Vault.
Also, a 12mm length bolt would probably be more appropriate, according to the PET. |
Lo-Fi Version | Time is now: 1st June 2024 - 12:30 AM |
