Jug Removal, Any tricks or tools to remove Head Studs? |
rebelmdot |
Jan 25 2008, 04:14 PM
914ini Group: Members Posts: 224 Joined: 25-January 08 From: Tennessee Member No.: 8,625 Region Association: South East States |
I am new to board, and tearing down 1976 2.0. Having trouble with getting jugs off, any assistance would be appreciated. I guess I will be doing as much as I can and then end up calling Jake!! (IMG:style_emoticons/default/headbang.gif)
SLITS |
Jan 25 2008, 04:43 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
If you can't slide the barrels off the studs you have a big problem.
Has the engine been sitting for a long time? Has it ingested copius amounts of water? Did the crank turn thru 360 degrees? |
Twystd1 |
Jan 25 2008, 04:46 PM
You don't want to know... really..... Group: Members Posts: 2,514 Joined: 12-September 04 From: Newport Beach, California Member No.: 2,743 |
AFTER pulling all the nuts off the heads. Then removing the heads.
You can tap the cylinders with a rubber mallet back and forth till they come loose. A propane torch on the block can help sometimes if someone used a hard glue like sealant to glue the jugs in. You can also squirt the base of the cylinders with PB Blaster to break down the sealant. Let sit over night. Tap and pull. In a worst case scenario. Curse at em... it works for me. By the way... Buy the Jake video if you are going to continue down this path. It make it all that much easier to do. C |
benalishhero |
Jan 25 2008, 05:49 PM
Member Group: Members Posts: 313 Joined: 28-November 07 From: Portland, Maine Member No.: 8,384 Region Association: North East States |
Sounds like rings are stuck to jugs.
Secure the jugs and turn the motor over to free them up. Or dead blow them off. |
Dr Evil |
Jan 25 2008, 09:12 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Um, did you remove the air guides under the cylinders? I have been hung up on those before (IMG:style_emoticons/default/wink.gif) Make sure all the tin is removed from under the cylinder as it will hold them fast.
rebelmdot |
Jan 25 2008, 09:59 PM
I am new to board, and tearing down 1976 2.0. Having trouble with getting jugs off, any assistance would be appreciated. I guess I will be doing as much as I can and then end up calling Jake!! (IMG:style_emoticons/default/headbang.gif) Just got home from work. Have Coors Light, Rubber Mallet, and knowledge that you passed along to me. I actually ordered Vol 8 from Jake, but it has not arrived yet. Thank you for the responses. Stay tuned, I will have many more. |
Jake Raby |
Jan 26 2008, 12:57 AM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
If you had my video you'd know exactly how to pull them off !!!
But we'll help even if you don't :-) |
rebelmdot |
Jan 26 2008, 02:04 AM
If you had my video you'd know exactly how to pull them off !!! But we'll help even if you don't :-) It is bought and paid for and hopefully on the way. I will be in touch soon to let you know which engine I want!! Your website makes me feel like a kid in a candy store or a bull in a china shop, I am not sure which yet. Thank you for the pics on your site, I do not think that I would have gotten this far without them. Any way, all four jugs off, but I am tired as it is 2 am here. |
Lo-Fi Version | Time is now: 8th June 2024 - 06:42 PM |
