| yarin |
Feb 20 2008, 07:02 PM
'14-X'in FOOL ![]() ![]() ![]() Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States |
I'm about to re-coat my exhaust and do a little bit of welding work so I figured why not weld on a few EGT 1/8" npt bungs while i'm at it. Does anyone know what the ideal position is for an EGT sensor is? Also which sensor is recommended?
| orange914 |
Feb 20 2008, 07:36 PM
http://5starmediaworks.com/index.html ![]() ![]() ![]() ![]() Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
I'm about to re-coat my exhaust and do a little bit of welding work so I figured why not weld on a few EGT 1/8" npt bungs while i'm at it. Does anyone know what the ideal position is for an EGT sensor is? Also which sensor is recommended? the closer to the head the better, for quick heating and acuracy. you can go down stream but you'll need the more expensive 3 wire units that self heat geez... sorry i was thinking you said o2 sensor (IMG:style_emoticons/default/blink.gif) close to the head would be my quess mike |
| McMark |
Feb 20 2008, 07:40 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
Yup, close to the head. I put them near the 90* bend where the exhaust changes direction from downwards to backwards.
I also like the clamp on EGT probes just fine. (IMG:style_emoticons/default/wink.gif) |
| toon1 |
Feb 20 2008, 10:42 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
Yup, close to the head. I put them near the 90* bend where the exhaust changes direction from downwards to backwards. I also like the clamp on EGT probes just fine. (IMG:style_emoticons/default/wink.gif) Hey Mark , what ex. temps are you seeing?? |
| Twystd1 |
Feb 20 2008, 11:17 PM
You don't want to know... really..... ![]() ![]() ![]() ![]() Group: Members Posts: 2,515 Joined: 12-September 04 From: Newport Beach, California Member No.: 2,743 |
I'm with Mark.
I saw a high of 1350 at peak torque for short durations floored going up hill. (Less than 5 seconds at that temp) When the engine pulls past peak torque. The temp goes down fast. Normal driving. 850 - 1200+ going up hill. Hi EGTs at cruise throttle openings on a flat freeway don't mean much to me. High (percieved) EGTs at cruise won't hurt the engine. The temps of when the engine is trying to achieve max torque and HP has great meaning to me. (I.E. WOT) On carbs. 2.5 litre Type IV with 9.5 - 1 static CR and a High RPM cam. Revs to 8K+ no probs. I also had 1/8 holes in the 90 degree bend below the head as per McMark. I think Chris-N-Prider now has those headers on his car. Still has the 1/8 holes for the quad EGT probes I think. Thats my experience. Yours may well be different. Clayton |
| McMark |
Feb 21 2008, 12:28 AM
I'm seeing between 40 degrees and 65 degrees.
My car's been sitting... (IMG:style_emoticons/default/av-943.gif) |
| rhodyguy |
Feb 22 2008, 09:56 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
these suggestions are for cars with headers, yes? how would one deal with egt sender placement when running ss hes?
k |
Lo-Fi Version | Time is now: 10th March 2026 - 07:33 AM |
