Poly bushing grease?, what to use |
Aaron Cox |
Jan 25 2004, 04:21 PM
im installing new poly bushings from pelican (came in a sack of four....they have 2 different part numbers...how can i tell which is front/back) (IMG:style_emoticons/default/mad.gif)
anyway, after i cut small grooves in them, what lubricant can i use (didnt come with any/didnt buy any) can i use lithium white grease? please help |
TimT |
Jan 25 2004, 04:24 PM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
gorilla snot!!
use a waterproof grease, like you would use for a boat trailers bearings |
Aaron Cox |
Jan 25 2004, 04:26 PM
so not regular wheel bearing grease like the torsion bars?
also- they arent labeled front or back, just have 2 sets of part numbers. which is front, ehich is rear? are they identical? |
Jeroen |
Jan 25 2004, 04:56 PM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
IIRC the bushings have "front" or "rear" engraved in the flanges
Order some of the bushing grease... It's weird stuff, not comparable to any other grease I've seen before cheers, Jeroen |
Qarl |
Jan 25 2004, 04:57 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
whale snot, not gorilla snot.
Aaron Cox |
Jan 25 2004, 04:58 PM
the bushings both have part numbers identical, except the last #, one is a 7, other is 8. they dont say front or rear.
can i get this bushing lube at flaps? so no go on wheelbearing grease? |
Qarl |
Jan 25 2004, 05:02 PM
No go on bearing grease.
Use synthetic boat bearing grease |
Jeroen |
Jan 25 2004, 05:05 PM
QUOTE(acox914 @ Jan 26 2004, 12:58 AM) the bushings both have part numbers identical, except the last #, one is a 7, other is 8. they dont say front or rear check the pelican website for the part#'s they also sell the fronts / rears separate cheers, Jeroen |
ArtechnikA |
Jan 25 2004, 05:12 PM
QUOTE(acox914 @ Jan 25 2004, 02:58 PM) can i get this bushing lube at flaps? i'd be really surprised ... i bought a little tub of the stuff - about the size of a 35mm film can - 1 ounce, i believe - from Performance Products. that'll do a few cars or one car a lot of times, even if you use it on every bushing. white stuff, contains Teflon, incredibly sticky, like Teflon-bearing honey. it's not expensive - $8 maybe. |
Aaron Cox |
Jan 25 2004, 05:18 PM
QUOTE(Jeroen @ Jan 25 2004, 04:05 PM) QUOTE(acox914 @ Jan 26 2004, 12:58 AM) the bushings both have part numbers identical, except the last #, one is a 7, other is 8. they dont say front or rear check the pelican website for the part#'s they also sell the fronts / rears separate cheers, Jeroen i did. parts cary diffferent numbers than theyre website (IMG:style_emoticons/default/mad.gif) i dont even think theyre wetmeister (IMG:style_emoticons/default/sad.gif) |
Dave_Darling |
Jan 25 2004, 06:30 PM
Check out a boating supply house for the grease.
As for the bushings, try emailing tom@pelicanparts and asking. He's the Big Cheese (well, him and Wayne) and he's a "parts guy" who has access to all that sort of info. --DD |
TimT |
Jan 25 2004, 06:37 PM
With the amount of fitting you have to do to make the bushings work, the part numbers are irrelevant.
You will be grinding,filing etc to make the bushings work... chose a pair and assign them as the front. the others as the rear... |
MarkV |
Jan 25 2004, 07:43 PM
Fear the Jack Stands Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
You can get it at Ace Hardware in the plumbing section. It is used for faucet O rings and is good for 450 degrees and won't wash off. It comes in a 1/2 ounce container & costs 3 or 4 dollars.
Attached image(s) |
TimT |
Jan 25 2004, 07:47 PM
(IMG:style_emoticons/default/beerchug.gif) Mark, thats cheap gorilla snot.............. you could easily pay 3 times that much in a marine store.. (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif)
Lo-Fi Version | Time is now: 8th June 2024 - 07:12 AM |
