| seanery |
Jan 29 2004, 04:45 PM
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,857 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
I just talked to the shop in LA that has my blue car. This motor is back together and bolted in the car again. It doesn't look the same. The shroud and associated pieces are now silver.
(IMG:http://seanlee.tv/914/914engine010.jpg) more pics can be seen at Sean's 914 stuff |
| Jeroen |
Jan 29 2004, 05:10 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
(IMG:style_emoticons/default/wub.gif) (IMG:style_emoticons/default/wub.gif) (IMG:style_emoticons/default/wub.gif)
cheers, Jeroen |
| Gint |
Jan 29 2004, 07:34 PM
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,108 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Good news!
Hop on a plane and come out to Dunkle's. You can obviously afford it. (IMG:style_emoticons/default/wink.gif) (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/beer.gif) |
| seanery |
Jan 29 2004, 07:48 PM
I WISH I could afford it.
It's not drivable yet. Not wired or plumbed. Just bolted in. |
| drew365 |
Jan 29 2004, 08:57 PM
These are the good old days! ![]() ![]() ![]() ![]() Group: Members Posts: 2,004 Joined: 29-December 02 From: Sunny So. Cal. Member No.: 37 |
What shop is it in? Maybe a few of us could stop by and drool on it for you!
| seanery |
Jan 30 2004, 07:38 AM
Precision Tech in Marina Del Rey. The complex is being torn down in a couple months to make way for big $ high rise condos. So he's trying to get as many cars done before he has to move.
| Eddie914 |
Jan 30 2004, 11:52 AM
Unregistered |
How much power do you expect from that beautiful motor?
40IDA 3C Webers? Droool! Eddie |
| seanery |
Jan 30 2004, 11:53 AM
yes those are the ones.
210 is the hope/dream. We'll see how it did when I get it back here and on a dyno. It'll be interesting to see how it compares against a stock 3.2. |
| Eddie914 |
Jan 30 2004, 12:20 PM
Unregistered |
The '71 914 I recently acquired has a 2.7 with 40IDA Webers and Bursch headers.
How much power do you think the 2.7 has? The PO (previous owner) bought the 2.7 in the early '90's with the Webers already installed and is not sure of the internals. So, I have got to assume that the motor has stock pistons and cams. Is there any way to determine the piston and cam setup with the engine still in the car? How about a compression test? How much compression should 2.7 CIS pistons produce? IIRC Compression Ratio is 8.5:1 How much compression will the RS piston produce? Compression Ratio of 10.5:1? Thanks Eddie |
| seanery |
Jan 30 2004, 12:36 PM
Eddie, I'm sorry, but I don't have the info you need.
The CIS cams are really mild, my motor has been fitted with S cams and RS pistons. There is a bit of compression increase, but I'm not sure what stock pistons are. The heads were ported, too. I didn't do the work, my shop in LA did all the work putting it together. When this project was started I lived on a boat (no garage) and was working 75 hr weeks, so money was easier to come by than time. If I were doing it now, I'd do much more of the work myself. |
| J P Stein |
Jan 30 2004, 12:39 PM
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
The RS spec piston is also 8.5:1.
To see what pistons are there, a bore scope thru the spark plug hole. For cams, check the lift at a valve........there are "some" tools required (IMG:style_emoticons/default/wink.gif) The stock 2.7L hp were between 150 and 175 hp, depending on year/model. Most 2.7s were the 165 hp S model (75-77). Headers & Webers will definitley add 10 hp to these. More costs money, but is fairly easy, partswise. |
| Doug Leggins |
Jan 30 2004, 04:47 PM
Senior Member ![]() ![]() ![]() Group: Benefactors Posts: 1,358 Joined: 6-February 03 From: Nashville, Indiana Member No.: 261 Region Association: None
| seanery |
Jan 30 2004, 05:46 PM
yessir! need a bigger garage!
| Doug Leggins |
Jan 30 2004, 07:49 PM
Would really like to see the blue one. I've never had the op to check out a six very well.
Prolly get a look, get hooked and then add to the project list - lol |
| seanery |
Jan 30 2004, 07:51 PM
That's ok, the one your doing now will work nicely (as a 6)!
BTW, whitey is gonna be a -6, too (a 3.2 from Boxstr). |
Lo-Fi Version | Time is now: 27th July 2026 - 03:30 AM |
