> Carbs VS FI, Which is better?
Carbs VS FI
Which is better?
Carbs because... [ 35 ] ** [27.34%]
FI because... [ 93 ] ** [72.66%]
Total Votes: 128
Guests cannot vote
dbgriffith75
post Sep 16 2008, 04:08 PM
TheGrif
So basically I'm just curious here on who's opinion is what and why. I might have seen a similar post a while back but I don't remember for sure.
My personal opinion is carbs. I don't know what a new injector for a 914 is going for but generally speaking carb kits are cheaper than new injectors. Plus, I like trying to fine tune carbs- if one is set right the engine can be extremely efficient. My teener is set up for carbs and I plan to leave it that way.
5 Pages V  1 2 3 > »
Replies(1 - 19)
melnyk
post Sep 16 2008, 04:43 PM
QUOTE(dbgriffith75 @ Sep 16 2008, 06:08 PM) *
how efficient? i think i have a blown mps and i personally dont like over complicated devices. i would like 25-27 mpg. id so i think im just going to go that route if i can get this mileage. my car isnt a DD and a carb is way easier to diagnose for me.
BarberDave
post Sep 16 2008, 04:57 PM
Barberdave
I have Carbs, i like them. How ever I voted for F.I.. Never haveing F.I. I would
like to play with that. More power, adjustability , and original. I 'm nut's i
guess!!!! Dave (IMG:style_emoticons/default/slap.gif)
Lavanaut
post Sep 16 2008, 05:03 PM
Hungry Mind : Thirsty Gullet
Try a search...
http://www.914world.com/bbs2/index.php?showtopic=75380
http://www.914world.com/bbs2/index.php?showtopic=67433
http://www.914world.com/bbs2/index.php?showtopic=37904
http://www.914world.com/bbs2/index.php?showtopic=30741
...just to name a few. (IMG:style_emoticons/default/bye1.gif)
jasons
post Sep 16 2008, 05:08 PM
Jackstand Extraordinaire
I (IMG:style_emoticons/default/wub.gif) DJET! When its properly set up, it works great.
Outside of a stock motor though, I'll take Dellortos.
jd74914
post Sep 16 2008, 05:11 PM
Its alive
My L-Jet car runs great. (IMG:style_emoticons/default/biggrin.gif)
On a side note, I'm too young to have tons of experience with carbs, so any warmed up thing I build will have PEFI on it. (IMG:style_emoticons/default/smile.gif)
TheCabinetmaker
post Sep 16 2008, 05:57 PM
I drive my car everyday
Jeez, here we go again.
So.Cal.914
post Sep 16 2008, 06:01 PM
"...And it has a front trunk too."
Why?..Cause. (IMG:style_emoticons/default/smile.gif)
type47
post Sep 16 2008, 06:07 PM
Viermeister
FI because it was factory installed
FI because it is more modern than carbs
FI because it's more efficient
IMHO
toon1
post Sep 16 2008, 06:11 PM
FI is better unless you like carbs, then carbs. are better (IMG:style_emoticons/default/dry.gif)
Personally, I'm on the no carb. diet.
Try the search from the link's above, this discussion has been beat to death.
So.Cal.914
post Sep 16 2008, 06:14 PM
Carbs because they sound Great. (IMG:style_emoticons/default/smile.gif)
Carbs because it gives better low end. (IMG:style_emoticons/default/smile.gif)
Aaaaaaand, Carbs because the POS FI kept breaking down and leaving me stranded all over Hells Acre. (IMG:style_emoticons/default/mad.gif)
IMHO (IMG:style_emoticons/default/biggrin.gif)
Todd Enlund
post Sep 16 2008, 06:28 PM
Resident Photoshop Guru
I voted FI because it is infinitely more tunable. You didn't specify stock FI or aftermarket... FI offers better MPG, better power, better driveability, all in the same tune. Carbs you pretty much need to decided how you want the car to run, and you'll sacrifice somewhat in other areas.
But, I plan on using 44 IDFs on my 2258. In my case, they will cost about 10% of what a comparable FI system would cost me. Maybe somewhere down the road, I will switch to FI, but it will be pretty low on my priority list.
r_towle
post Sep 16 2008, 06:34 PM
Custom Member
I would say this.
Preface...I have a Djet and and Ljet car.
For simple drive and go, the stock FI is fine, once you troubleshoot it and replace any worn parts.
Unfortunately the TPS and MPS are NLA...say that three times fast.
The can be tuned and can be modified for larger motors, but you really need to have your wits about you to make it work...it simple, but fubar if you change the wrong thing in the motor.
Carbs are way more flexible, but you suffer from poor mileage and they run like crap for the first 10 minutes.
Modern FI would be my choice, something with an O2 sensor and a feedback loop to monitor the system..
It really amazes me how much HP these modern cars get from the modern FI system...its just much better technology overall.
Rich
EyeTrip
post Sep 16 2008, 06:52 PM
Love the sound of dual webers
Once setup, carbs are more reliable than the 40yr 1st gen injection
Very clean install over injection
Now, I would like to megasqirt a 1911. I think that would be fun.
dbgriffith75
post Sep 16 2008, 06:53 PM
TheGrif
the TPS and MPS are NLA!
mwa ha ha... I accept your challenge and await your rebuttle! (IMG:style_emoticons/default/biggrin.gif)
EyeTrip
post Sep 16 2008, 06:54 PM
QUOTE(r_towle @ Sep 16 2008, 05:34 PM) *
Rich
I agree 100%
azbill
post Sep 16 2008, 07:00 PM
FI is the way to go. I'm running the Emerald M3D ECU with Jennvey throttle bodies other then the noise form the Jennveys the system is great. It took awhile to get ECU programmed but once it was set it is fantastic.
Bleyseng
post Sep 16 2008, 07:25 PM
Aircooled Baby!
QUOTE(EyeTrip @ Sep 16 2008, 05:52 PM) *
Love that sound? cuz thats all you can hear carbs are soo loud. I have a CD player and like to listen to music driving not that sucking sound.
Once setup? yep, and then they go out of sync again and again.
Clean? Stock FI is really clean and reliable as its still going strong.
Low end power? Bow to FI as it has better low end power.
Tuneable? Bolt on the stock parts and its tuned or if you have a 2056 w/ mild cam adjust the MPS and forget about it.
Plus you can get 30mpg with Djet / Ljet and FI has built in altitude adjustment for those up into the mountain road days.
In 1999 I went back to djet pulling the 40 dells and have never looked back, never been broke down by the side of the road either with djet. Carbs? several times...and they are sitting on the shelf gathering dust...
scotty b
post Sep 16 2008, 07:30 PM
rust free you say ?
QUOTE(So.Cal.914 @ Sep 16 2008, 04:01 PM) *
God I hope that's just drool on that filter lid (IMG:style_emoticons/default/blink.gif)
TheCabinetmaker
post Sep 16 2008, 08:20 PM
QUOTE(Bleyseng @ Sep 16 2008, 08:25 PM) *
(IMG:style_emoticons/default/agree.gif) 100%
5 Pages V  1 2 3 > »
- Lo-Fi Version Time is now: 2nd April 2026 - 11:08 AM
