Need tranny rebuild help, James? anyone with R/P help |
brant |
Feb 21 2004, 12:07 PM
914 Wizard Group: Members Posts: 11,634 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
good morning all..
Can someone with ring and pinion or tranny experience answer a question for me? I'm trying to do a quick/easy rebuild. Victim tranny reputably has a whinning bearing noise... suspect that its the intermediate plate bearing.... what would happen if I took a full gear stack (including intermediate plate) out of a known good box and put into this case? how good/bad is this going to be? I'm concerned that the R/P depth will no longer be correctly adjusted? Please Help... brant |
meursault |
Feb 21 2004, 07:54 PM
Idjit Savant Group: Members Posts: 290 Joined: 26-February 03 From: San Diego, CA Member No.: 355 |
QUOTE what would happen if I took a full gear stack (including intermediate plate) out of a known good box and put into this case? how good/bad is this going to be? I'm concerned that the R/P depth will no longer be correctly adjusted? More than that, the ring and pinion needs to be a matched set. If I understand you correctly, you want to swap out that entire assembled gear cluster, and mixing up the ring and pinion set is simply a bad idea. What's wrong with just running this known good box? By the way, any time you change the pinion shaft bearing, you need to reset the depth. |
TimT |
Feb 21 2004, 08:32 PM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
914's dont make enough power for this to really worry ou....... the song can be annoying though
Red-Beard |
Feb 21 2004, 09:10 PM
"Ya canna change the laws of Physics" Group: Benefactors Posts: 1,124 Joined: 11-February 03 From: Houston, TX Member No.: 288 Region Association: None |
I can't answer your question on the other board, but I can here!
So the answer is: 4th-5th shift rod, ball, spring with stick inside, ball, 2nd-3rd shiftrod, metal pill, 1st-rev shiftrod, ball, spring, 14mm cover. Attached thumbnail(s) |
brant |
Feb 22 2004, 01:10 AM
james,
your a life saver.... I got it right, but I feel much better with your post and knowing that I got it right... merusault, 2 things... a) the known good box was a tail shifter, not a ss. (IMG:style_emoticons/default/cool.gif) when you mention resetting the R/P everytime the bearing is changed... which of the two pinion shaft bearings are you referring too..... It makes since for the end bearing but what about the intermediate bearing? well... anyways thanks to all who helped out. I finished and decided to convert my tail box to a side shifter by changing the shift rods and tail cover.. now I've got an engine question.. but I'll start a new thread brant |
Lo-Fi Version | Time is now: 4th June 2024 - 04:54 PM |
