how do you install new trunk rollers? |
rfuerst911sc |
May 9 2009, 04:28 PM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
I have new brass rollers to install on the rear trunk torsion rods. How the heck do you unload the torsion bars to slide on the rollers?
SGB |
May 9 2009, 04:39 PM
just visiting Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
Use a deep well 10mm socket on a long extension as a tool. I've always had the trunk removed, so that might be neccessary- but stick the socket down over the torsion spring then lever it down to clear the pivot, Wear some thick gloves in case something gets pinched or goes flying.... It will be easy if there is someone who can reach in then and slide off the old roller and slide on the new one (no circlips or retainers- the spring holds it in place). If you are by yourself, you can let the extension up very slowly until it contacts the underside of the body panel by the hood opening- and just leave the whole assembly in place while tyou swap out the rollers. I've even driven my car with one of these holding the spring down. Its a little scary but turns out no big deal...
r_towle |
May 9 2009, 05:07 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
just lean on the socket extension with one hand...move quick...pull off the old roller and put on the new one.
RIch |
carr914 |
May 9 2009, 05:13 PM
Racer from Birth Group: Members Posts: 119,001 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
SirAndy |
May 9 2009, 05:22 PM
Resident German Group: Admin Posts: 41,677 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I have new brass rollers to install on the rear trunk torsion rods. How the heck do you unload the torsion bars to slide on the rollers? I wonder if anyone ever checks the "Lapuwali Classic Thread Forum" ... (IMG:style_emoticons/default/confused24.gif) http://www.914world.com/bbs2/index.php?showtopic=39320 (IMG:style_emoticons/default/shades.gif) Andy |
Katmanken |
May 9 2009, 06:03 PM
You haven't seen me if anybody asks... Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest |
Be careful...
Wasn't it Dave Darling that got whacked in his chest (by the evil tool) and thought his heart was gonna stop???? Ken |
Dave_Darling |
May 10 2009, 10:47 AM
I was using a box-end wrench, not a socket. The wrench rotated, allowing the torsion rod to move upward. It hit the roller pivot, rocketing the trunk hinge upward at roughly Mach 3, straight into my chest.
Ouch... --DD |
rick 918-S |
May 10 2009, 10:53 AM
Hey nice rack! -Celette Group: Members Posts: 20,492 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
naro914 |
May 10 2009, 06:15 PM
Losing my mind... Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States |
or B ) let someone else do them. |
black73 |
May 10 2009, 06:36 PM
Senior Member Group: Members Posts: 516 Joined: 23-March 05 From: Nashville,TN Member No.: 3,801 Region Association: South East States |
I used a pipe wrench on the end of the torsion rod... like the 10mm socket trick, only with more leverage.
Dave_Darling |
May 10 2009, 06:42 PM
I wouldn't use the pipe wrench. Too muc chance of it rotating like my box-end wrench did...
--DD |
black73 |
May 10 2009, 06:48 PM
Not really. The pipe wrench was made for holding things. (IMG:style_emoticons/default/rolleyes.gif)
JoeSharp |
May 11 2009, 07:50 AM
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
Someone makes a tool for it. Just a bar of steel with a notch in it. I did one out of the froming stake.
Bartlett 914 |
May 11 2009, 02:05 PM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
Someone makes a tool for it. Just a bar of steel with a notch in it. I did one out of the froming stake. (IMG:style_emoticons/default/agree.gif) An easy to make one is to drill a hole in a bar of steel near the edge then hack saw to the side making a notch. All the other idea's scare me. |
watsonrx13 |
May 11 2009, 06:27 PM
Advanced Member Group: Members Posts: 2,734 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
I have new brass rollers to install on the rear trunk torsion rods. How the heck do you unload the torsion bars to slide on the rollers? Rick, give me a call, I have a reproduction of the factory tool to hold the torsion bars down, while changing the roller.... Cell 813 390-1891, home 813 719-7518... -- Rob |
zonedoubt |
May 12 2009, 09:57 AM
Canadian Member Group: Members Posts: 668 Joined: 14-May 03 From: Vancouver, BC Member No.: 696 Region Association: Canada |
...with eye & face protection.
rfuerst911sc |
May 12 2009, 03:20 PM
I have new brass rollers to install on the rear trunk torsion rods. How the heck do you unload the torsion bars to slide on the rollers? Rick, give me a call, I have a reproduction of the factory tool to hold the torsion bars down, while changing the roller.... Cell 813 390-1891, home 813 719-7518... -- Rob Rob I'll give you a call tomorrow. Thanks |
rfuerst911sc |
May 13 2009, 05:17 PM
The suggestions from you guys was helpful and tonight I attacked the torsion bars with a 3/4 drive 9mm socket on an extension. Only took about 2 minutes and both sides were done. I took an inventory and I still have all fingers,teeth and eyes so we're good to go (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 8th June 2024 - 11:23 AM |
