The eurorace header just showed up, YES! |
purple |
Oct 3 2007, 10:12 PM
Pigeon feeders attract me Group: Members Posts: 938 Joined: 24-July 07 From: Houston, TX Member No.: 7,942 Region Association: None |
Hey guys, this is something of a continuation thread of these last two threads.
http://www.914world.com/bbs2/index.php?showtopic=76498 http://www.914world.com/bbs2/index.php?showtopic=76175 The eurorace header showed up today! YES!!! Here is a pic of it sitting in the garage somewhat assembled. Now I have a couple questions: 1: Do I use only new copper gaskets? 2: Is there a specific procedure to preparing the gaskets prior to install? 3: Should I use those copper nuts or just double nut the stub pipes to the exhaust ports? 4: Should I do a little dance after putting it all on without any pulled studs? I'll post a pic of the dual motorcycle exhaust once I launch my other computer. If Jake signs in....how much will this help my engine over that dual motorcycle exhaust? Attached thumbnail(s) |
purple |
Feb 24 2008, 11:30 AM
I'm resurrecting this thread...but can someone out there show me what the clutch cable plate looks like when they drilled it to make it rotate to clear the headers?
I think i've melted 2 clutch cables trying to get this right. I have the summit heat shield on there, but i didnt rotate the pulley bracket because i didnt know where to drill it. I also have the cables zip tied to the case, but i'm thinking this is a far from optimal solution. any input would be greatly apprecieated! |
Lo-Fi Version | Time is now: 7th June 2024 - 02:21 AM |
