3D914s 914-6 SHO 3.2L v6, Build Thread - Project for sale. See classifieds |
3d914 |
Mar 30 2008, 06:59 PM
Senior Member Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
OK here goes . . .
I sold my beautiful Ravenna 914/2.0 so I could develop a custom 914 in good conscience. The sweet Ravenna was to stock to cut up and customize, & an admiring buyer wanted to return her to full stock - so it seemed like the perfect match. Now I've found a 74 1.7 that someone has already led down the path of the Dark Side (as the puritans see it), and I'll simply take it the rest of the way. Just as a warning - this is not meant to be a factory GT look alike or anything close. I want to incorporate some of my own ideas and those I like that others have done. In fact at this point its not even going to be a Porsche six. My initial intent is to go with the Ford 3.0L SHO. Plans may change when I get to that point, but that's where I'm headed. It seems reasonable to start with Before pics, so heres a couple of the car before I started any dismantling: |
3d914 |
Mar 30 2008, 07:56 PM
Well the portable sanding booth worked well. I started on the right rear fender using a 6in orbital sander. Since I'm new to pneumatic tools I wanted to start off with just 80 grit so as not to sand right through the fender. Within 30 minutes I moved down to 40 grit and was able to make good progress.
What I discovered though only indicated that more work was ahead. It appears my friends at Maaco used Body Filler as their means of bonding the flares to the metal. This won't do. After consulting with the body shop that did the terrific repair work on Ravenna's tail end, it seems there will be more work needed as I thought. Since they did not use any FG matt and resin to bond the flares to the metals fenders, I will need to sand down the existing filler so that this can be done. I also want to repeat the similar process underneath and close off the gap between the flares and the cut fender edge to prevent moisture from getting up underneath the fiberglass. |
Lo-Fi Version | Time is now: 10th June 2024 - 11:58 PM |
