3d914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region ![]() |
OK here goes . . .
I sold my beautiful Ravenna 914/2.0 so I could develop a custom 914 in good conscience. The sweet Ravenna was to stock to cut up and customize, & an admiring buyer wanted to return her to full stock - so it seemed like the perfect match. Now I've found a 74 1.7 that someone has already led down the path of the Dark Side (as the puritans see it), and I'll simply take it the rest of the way. Just as a warning - this is not meant to be a factory GT look alike or anything close. I want to incorporate some of my own ideas and those I like that others have done. In fact at this point its not even going to be a Porsche six. My initial intent is to go with the Ford 3.0L SHO. Plans may change when I get to that point, but that's where I'm headed. It seems reasonable to start with Before pics, so heres a couple of the car before I started any dismantling: ![]() ![]() |
3d914 |
Thanks for the encouragement guys. I think this one is going take more than the summer to complete - maybe two!
OK, I've reached one of those - "Am I on the right track" moments (Bodyshop newbie). I've sanded down enough to see that adjacent to the edge of the FG flares there is body filler over the metal all the way around the flare. Here's a pic. Yellow indicates metal, red indicates body filler. ![]() Since I want to do this correctly and apply FG & resin to adhere the flare to the metal, I need to get all the adjacent body filler sanded down to metal - right? And I should have a small lip where the flare overlaps the metal fender that will get filled with the bonding FG - right? See some more pics. ![]() Now to move over to the driver's side. This is not going to be pretty. (IMG:style_emoticons/default/barf.gif) |
jasons |
Jackstand Extraordinaire ![]() ![]() ![]() ![]() Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None ![]() |
Since I want to do this correctly and apply FG & resin to adhere the flare to the metal, I need to get all the adjacent body filler sanded down to metal - right? I would. Glassing to bondo is like the tail wagging the dog. And I should have a small lip where the flare overlaps the metal fender that will get filled with the bonding FG - right? Seems reasonable to me. A propane torch makes removing bondo a lot easier. Not sure what it would do to your glass flares though. Are you planning to pull the flares off or leave them riveted on and glass them to the steel? |
Lo-Fi Version | Time is now: 10th June 2024 - 05:08 PM |
