> '7X 2.7-6 Projekt Thread, Updated 5/4/08 - IT IS ALIVE... well, sort of...
KaptKaos
post Dec 17 2007, 12:05 AM
Family
I finally got my car moved around in the back so that I can get it up onto jack stands and take a look around.
My short term goal is to get the oil changed, swap the gas tank, charge the battery and try and fire her up. I took a few steps towards that today.
First, I was under there cleaning stuff up. I noticed this on the passenger side of the trans.
I assume that it is the throttle cable, but being this is my first /6, I need to confirm.
Secondly, I drained the oil from the case and the tank. For those that don't recall, here is my 911 tank, cut into the floor.
Problem is that when I drained the case and the tank, I only got 1/2 gallon of oil. I was expecting about 3.5 gallons (14 qts +/-). Not even close. This is my first dry sump motor, so am I missing something?
Here is a picture of the engine mount bar.
I don't know if this is stock, custom, aftermarket or ??? A little help pls. The mount bar sits so low that the side shift trans rod is above it.
Lastly, when I got the car, the PO said that he had buggered up the trans. Its a side shifter. I cleaned it up a little and took off the shift rod head and the ball socket. It's a new socket bushing which is nice.
I was able to move the selector through all gears. I noticed that the shift rod head was about an inch longer than the one on my car. In fact, it looked as if it was extended somehow. It's odd. I noticed this because I had to put the bushing on the ball and snap it down, before inserting it into the shift rod head. If I didn't do that, the shift rod head was so deep that I couldn't push it on. I am hoping that I get lucky with this.
Also, the cone set screw was replaced with a longer set screw, with a square head, that is drilled so it can be wired for additional safety.
Anyway, more to come soon. I have my work cut out for me.
KaptKaos
post May 4 2008, 06:24 PM
Family
IT IS ALIVE! (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif)
But.............
It won't idle. It kicks over and spits for a second or two and dies. So I am not out of the woods yet.
Another problem, that I have been fearing, may have reared it's ugly head too. The starter wouldn't disengage very well before. I'd have to hit the switch from time to time to get it to stop cranking. I heard a nasty and assume that I might have dinged the flywheel. So I need to look for a starter now. (IMG:style_emoticons/default/headbang.gif)
Thanks to Ron, Slits and the Professor for the fuel dizzy. I think that really helped. I need to get a claw hammer with a wider split to got those injectors out and cleaned. That's next.
SLITS
post May 4 2008, 11:23 PM
"This Utah shit is HARSH!"
QUOTE(KaptKaos @ May 4 2008, 05:24 PM) *
But.............
Starter is no problem Joe ... I have a few. Good job.
KaptKaos   '7X 2.7-6 Projekt Thread   Dec 17 2007, 12:05 AM
rick 918-S   Yes, that's your throttle linkage. I think you...   Dec 17 2007, 08:51 AM
KaptKaos   So does anyone have any clue as to why I only got ...   Dec 18 2007, 11:54 AM
sixnotfour   From the looks of the motor it has leaked a couple...   Dec 18 2007, 03:40 PM
KaptKaos   Do I check the level with the motor running? How ...   Dec 18 2007, 05:48 PM
Jeffs9146   Yes, put in about 9qts, start and check, Yes and...   Dec 18 2007, 06:02 PM
KaptKaos   Thanks Jeff :trophy: Oh, and what weight oel shou...   Dec 18 2007, 06:35 PM
Jeffs9146   That is a personal preferance. I am sure you will ...   Dec 18 2007, 06:48 PM
KaptKaos   I picked up a clean gas tank from Bruce out in Riv...   Dec 23 2007, 08:06 PM
Grimstead   1) There are two bolts that bolt the steering ra...   Dec 27 2007, 11:01 AM
KaptKaos   Oh, one other thing. The gas sender is enclosed i...   Dec 23 2007, 08:08 PM
Headrage   3/8th and 5/16 on the hose. The sender is a seale...   Dec 23 2007, 08:27 PM
Markeydoo   Kapt I have a 2.0l six with the quick six engine b...   Dec 23 2007, 08:48 PM
KaptKaos   Thanks Allan & Mark. I'll be stopping a...   Dec 23 2007, 09:27 PM
Twystd1   Do you have a oil line that runs from the trunk mo...   Dec 23 2007, 09:48 PM
KaptKaos   I drained from the bottom of the case and the bott...   Dec 24 2007, 12:14 AM
swood   Where is this "Flaps" of which you speak...   Dec 24 2007, 02:31 AM
KaptKaos   Where is this "Flaps" of which you spea...   Dec 24 2007, 08:31 AM
swood   Just givin you xmas sheet. Hope you have enough t...   Dec 24 2007, 02:41 PM
Twystd1   Crack (Loosen) all your oil lines that go from the...   Dec 27 2007, 01:24 AM
SLITS   1.) Line one goes from the bottom of the tank to ...   Dec 27 2007, 07:58 AM
dfwteenerpr   for what it's worth, a mechanic advised my bro...   Dec 27 2007, 10:02 AM
KaptKaos   Update It's not seized!!! :tr...   Dec 29 2007, 08:19 PM
euro911   Who the Fuch is this Mark character you mention, a...   Dec 30 2007, 01:25 AM
KaptKaos   Who the Fuch is this Mark character you mention, ...   Dec 30 2007, 10:11 AM
KaptKaos   So I went out there again today to try and start h...   Dec 30 2007, 05:29 PM
euro911   Have at it ... Pick your poison ... doing a litt...   Dec 30 2007, 06:32 PM
Aaron Cox   Get off your ass and get it running ! LOL ...   Jan 4 2008, 08:04 PM
Brando   How's the teener running Aaron?   Jan 4 2008, 08:10 PM
KaptKaos   :rotfl: :rotfl: Yeah, and this rain is gonna he...   Jan 4 2008, 08:27 PM
Headrage   How's the teener running Aaron? No one will...   Jan 4 2008, 08:39 PM
Aaron Cox   I drove it today......(around the block) I need t...   Jan 4 2008, 09:08 PM
Gint   This thing running yet? :driving:   Jan 5 2008, 09:03 AM
KaptKaos   Depending on the weather, I plan to pull the fuel ...   Jan 5 2008, 10:35 AM
KaptKaos   A little progress so far today. 1) It's not t...   Jan 31 2008, 02:19 PM
KaptKaos   Ok, so I got the fuel pump back in, and it's s...   Jan 31 2008, 05:06 PM
swood   Was it another holiday today...? :confused: :ch...   Jan 31 2008, 10:59 PM
KaptKaos   Was it another holiday today...? :confused: :c...   Jan 31 2008, 11:22 PM
KaptKaos   So today, I got some FI fuel line, and rigged it u...   Feb 2 2008, 05:12 PM
KaptKaos   :barf: Checked PP. The first thing is a fuel ac...   Feb 2 2008, 05:19 PM
KaptKaos   I put a new fuel filter on it today, and I "t...   Feb 16 2008, 06:40 PM
racerx9146   try pull the intake boot off the cis fuel distribu...   Feb 16 2008, 08:23 PM
KaptKaos   I was following Slits' CIS issues. IIRC - h...   Mar 29 2008, 09:52 PM
SLITS   Joe, the center piston is what HAS TO BE FREE. It...   Mar 30 2008, 08:11 AM
Gint   PS Gint ... I started to write this up for your si...   Mar 30 2008, 01:25 PM
SLITS   [quote name='SLITS' post='1014594' date='Mar 30 2...   Mar 31 2008, 12:44 PM
KaptKaos   :trophy: :trophy: :trophy: :trophy: :trophy: ...   Mar 30 2008, 09:45 AM
euro911   ... Danka Herr Doktor! I'd love to come o...   Mar 30 2008, 02:25 PM
KaptKaos   :rotfl: We really should build one of these. E...   Mar 30 2008, 02:50 PM
Eric_Shea   It's "Professor" H-E-L-L-O! ...   Mar 30 2008, 06:19 PM
Dr Evil   :popcorn: Mmm, Vicodin   Apr 1 2008, 02:43 AM
KaptKaos   IT IS ALIVE! :trophy: :trophy: But..........   May 4 2008, 06:24 PM
SLITS   [size=7][color=#FF0000]IT IS ALIVE! :trophy...   May 4 2008, 11:23 PM
shoguneagle   Great job and excellent support as always from fol...   Aug 17 2009, 09:03 PM
- Lo-Fi Version Time is now: 30th September 2026 - 11:03 PM
