3D914s 914-6 SHO 3.2L v6, Build Thread - Project for sale. See classifieds |
3d914 |
Mar 30 2008, 06:59 PM
Senior Member Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
OK here goes . . .
I sold my beautiful Ravenna 914/2.0 so I could develop a custom 914 in good conscience. The sweet Ravenna was to stock to cut up and customize, & an admiring buyer wanted to return her to full stock - so it seemed like the perfect match. Now I've found a 74 1.7 that someone has already led down the path of the Dark Side (as the puritans see it), and I'll simply take it the rest of the way. Just as a warning - this is not meant to be a factory GT look alike or anything close. I want to incorporate some of my own ideas and those I like that others have done. In fact at this point its not even going to be a Porsche six. My initial intent is to go with the Ford 3.0L SHO. Plans may change when I get to that point, but that's where I'm headed. It seems reasonable to start with Before pics, so heres a couple of the car before I started any dismantling: |
3d914 |
May 18 2008, 04:55 PM
I'm having a hard time deciding since I'd really like to use the SHO, so I decided to wait and collect more data on my top engine choices before I commit to one. It may just be a process of elimination.
Here is my current list of potential swaps. The blue rows are top choices based on the data I've found so far. I did get the remaining front flare sanded this weekend. So now I have a better scope of the repair work. For the fronts I'm just going to remove the remaining filler; leave the existing bonded flare in place; leave the existing clothe and resin blend, and put added clothe and resin on the back side as extra precaution. For the backs, I'm going to visit the body shop and see if they can give me some idea what the bonding material in the back is. If its acceptable, I'll leave the flares attached, but go through redoing all the blending and sealing of the front and back sides as it should have been done. If the bonding material isn't acceptable - they'll have to come off. |
KELTY360 |
May 23 2008, 10:04 PM
914 Neferati Group: Members Posts: 5,036 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
I'm having a hard time deciding since I'd really like to use the SHO, so I decided to wait and collect more data on my top engine choices before I commit to one. It may just be a process of elimination. Here is my current list of potential swaps. The blue rows are top choices based on the data I've found so far. I did get the remaining front flare sanded this weekend. So now I have a better scope of the repair work. For the fronts I'm just going to remove the remaining filler; leave the existing bonded flare in place; leave the existing clothe and resin blend, and put added clothe and resin on the back side as extra precaution. For the backs, I'm going to visit the body shop and see if they can give me some idea what the bonding material in the back is. If its acceptable, I'll leave the flares attached, but go through redoing all the blending and sealing of the front and back sides as it should have been done. If the bonding material isn't acceptable - they'll have to come off. I found a notation on the SVX/Vanagon site that the eg33 weighs 387# according to KEP. That is minus flywheel and clutch. The case and heads are aluminum alloy. |
Lo-Fi Version | Time is now: 10th June 2024 - 05:40 PM |
