3d914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region ![]() |
OK here goes . . .
I sold my beautiful Ravenna 914/2.0 so I could develop a custom 914 in good conscience. The sweet Ravenna was to stock to cut up and customize, & an admiring buyer wanted to return her to full stock - so it seemed like the perfect match. Now I've found a 74 1.7 that someone has already led down the path of the Dark Side (as the puritans see it), and I'll simply take it the rest of the way. Just as a warning - this is not meant to be a factory GT look alike or anything close. I want to incorporate some of my own ideas and those I like that others have done. In fact at this point its not even going to be a Porsche six. My initial intent is to go with the Ford 3.0L SHO. Plans may change when I get to that point, but that's where I'm headed. It seems reasonable to start with Before pics, so heres a couple of the car before I started any dismantling: ![]() ![]() |
3d914 |
Didn't do much this weekend. My son was home from college for just a few days to get everything ready for his summer internship. This included lots of little prep items for the 924S he taking over to CA to use during the summer. Biggest job was replacing the drive and balance belts & one tension roller. Went real smooth though.
I did take an extra couple days off though. So I was able to work on the front end a little. Started off by removing all the adhesive from the trunk firewall. Used the Aircraft Decal & Adhesive Remover. Works OK. I also removed the head lights, motors, assemblies, and all the associated wiring. ![]() And removed the trunk lid. ![]() You may not be able to notice in the pic, but the spliced every single wire in the front and only crimped the connections. I'll have to go through all this and solder connections, and add appropriate heat-shrink. Don't need any flaky electrical problems. I'll be deleting some of the wiring in the process - like the side marker lights. ![]() |
Lo-Fi Version | Time is now: 10th June 2024 - 04:16 PM |
